03 WRX jerks when i let off gas in lower gears
Results 1 to 9 of 9
This is a discussion on 03 WRX jerks when i let off gas in lower gears within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Whenever i let off the gas, or push back on it, in lower gears (it happens in higher gears too ...
    Registered User Rgw2kx's Avatar
    Oct 2010
    Ohio
    Whenever i let off the gas, or push back on it, in lower gears (it happens in higher gears too but not nearly as noticable) my car jerks. if i let off or push the gas in VERY easilly it does not do this. if i quickly let off the gas or press on it on the other hand, it just "bucks" pretty hard. any ideas? i was told to clean the throttle body and check the motor mounts for stiffness.
    May 2011
    It's natural on manual transmission cars. Or is it just extremely absurd jerking?
    Jan 2005
    Eh, whaaaaa?
    It's more than likely a mount and busing problem. Think, your car is now 8 years old and probably has quite a few miles on it with quite a few seasons. Rubber tends to soften and deteriorate and so drivetrain slop gets worse over time. When you have sudden torque or a sudden lack of torque the energy has to go somewhere, and when the mounts and bushings aren't able to absorb or dissapate that energy, you get lurching througout the drive train, which is absorbed by the rest of the car, hense the jerking.
    That's not to say it couldn't be something else, of course.
    Cody
    Oct 2010
    Ohio
    ok that makes sense, any suggestions on how to fix it?
    Moderator Donkey's Avatar
    Da boonies,Va
    Change the mounts.
    2002 FORESTER S
    1998 FORESTER S
    Registered User poly_poly-man's Avatar
    Feb 2010
    Rochester Institvte of Technorcery
    This has been happening to me, too, and getting worse. Pick up unabomber's sexy rearend on TIC. It's $95, and will take care of this to a major degree. The only other mounts, AFAIK, are engine and tranny mounts (which would both help this, certainly), and then the other bushings you can do are in the shifter (won't help this problem, but are probably worth it).
    Sometime before I end up going for the bushings (I'm a little short on cash right now), I'm thinking of taking a video of my rear diff as I drive around, just to see how bad it is. I know it's pretty bad at this point, because occasionally on an easy start, the car will just wobble back and forth with little power until it settles down.
    My big thread: The Used WRX Buying Checklist - Please Contribute!
    My current car: 2002 WRB WRX Wagon.
    Mods: GM BCS, Carberry SD rom, uppipe, AEM UEGO, Klunk Killer, F+R shifter bushings, head unit
    Registered User lytlec's Avatar
    Jan 2009
    Central PA
    Don't let off the gas...ever...
    My crappy Jetta I just bought does this too...and I thought it was odd...since my wrx doesnt do this...I found out its just normal.
    <-------- Taylor Swift.
    Hawk-Eye Alliance #137
    First Mods...what to do.
    Subaru Guide
    Nov 2009
    This happened to me once. I found one of the pitch stop bolts had become loose. Check that and report back.
    Oct 2010
    Ohio
    ok i will. im not sure when i will get the chance but i will report back asap
