Make sure all connections are tight and there are no leaks and that the MAF is plugged in. There has to be a leak somewhere if all you did was install the inlet.
This is a discussion on HELP ASAP!!! SILICONE INLET TUBE!!!!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Installed silicone intake tube and now the car won't run!!!! Any suggestions?...
"SCHIRRA~#16"HOLY F*CK'N A$$ CRACKERS!!!!!
Stink eye mob #727
2011 WRX DGM Hatch, Protuned Stage 1
Well I tripple checked everything.... and I was wondering if it would have to be tuned for more airflow..
Ok Ill keep tryn
My guess is it has to do with the MAF installation.
Take a picture of your engine bay.
There is a plug that you have to pull the metal prong out of the sensor and put back into the plug. It comes off the crack case vent its the only plug that I can think that you have to mess with when doing the turbo inlet
Ok Im uplaoding some pics now... Where is the location of this plug you speak of?
You might not have the plug I am talking about it might just be on the new models.
I can't figure it out... its stressing me out!
Pull off the lines one at a time, and check the (hold your laughter) metal nipples to make sure there is a seal. Have a friend try to start it up each time after you check each of the lines.
2006 WRX Limited -Pro-tuned VF-39, STI TMIC, STI factory I/C Sprayer, Throttle body Coolant Bypass, STI Exhaust, SPT Short Ram Intake, SPT Upper Front and Rear Strut Bar, Red Samco Radiator Hoses, STI Trunk, SPT Short Shifter, Aftermarket Rotors, Lamco Turbo Gauge, Catless Downpipe, Hella Supertones, RallyArmor Limited Edition Pink UR Flaps, 35% Tint, Grounding Mod, Walbro 255 Fuel Pump, SPT Heat Shield STI Piston Shift Knob!
Hawk-Eye Alliance #430
Are the metal nippels harder to seal?
Not particularly, but your engine bay looks like an '02 (I'm not 100%), so the vacuum lines may be a little dry or cracked, which would warrant a leak.
Yea Good Eye its and 03 lol still old as dirt tho lol I went over everything. It will start now but it will not boost and soon as the trubo starts to build psi it wants to die..
Hmm.... did the restrictor pill come out when you were pulling the lines? That would cause starting and boost problems.
