HELP ASAP!!! SILICONE INLET TUBE!!!!! - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 38 of 38
This is a discussion on HELP ASAP!!! SILICONE INLET TUBE!!!!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; o-ring good?...
  1. #31
    Aug 2009
    Canada/Ethiopia/Madagascar
    o-ring good?
    ...Rob.
  3. #32
    Moderator Donkey's Avatar
    Da boonies,Va
    If you unplug the MAF the ECU defaults to speed density using the MAP sensor. You have a leak somewhere. Either you did not hook up all the vacuum lines or something is not tight.
    2002 FORESTER S
    1998 FORESTER S
  4. #33
    Registered User Civic_jdm16's Avatar
    Sep 2009
    Clearwater, FL
    It looks good like there isn't any damage to it that I can see
    "SCHIRRA~#16" HOLY *****'N A$$ CRACKERS!!!!!
  6. #34
    Registered User MakeItRoar's Avatar
    Aug 2010
    Chicago, Illinois
    You can't actually see the MAF. What you see is the temp bulb that reads the temperature of the intake air, the MAF part is up inside the plastic.
    2006 WRX Limited -Pro-tuned VF-39, STI TMIC, STI factory I/C Sprayer, Throttle body Coolant Bypass, STI Exhaust, SPT Short Ram Intake, SPT Upper Front and Rear Strut Bar, Red Samco Radiator Hoses, STI Trunk, SPT Short Shifter, Aftermarket Rotors, Lamco Turbo Gauge, Catless Downpipe, Hella Supertones, RallyArmor Limited Edition Pink UR Flaps, 35% Tint, Grounding Mod, Walbro 255 Fuel Pump, SPT Heat Shield STI Piston Shift Knob!
    Hawk-Eye Alliance #430
  7. #35
    Sep 2009
    Clearwater, FL
    Yea I know that, I tried spraying a crap load of the crc up in there but no change...
  8. #36
    Registered User poly_poly-man's Avatar
    Feb 2010
    Rochester Institvte of Technorcery
    try borrowing a maf from a friend?
    My big thread: The Used WRX Buying Checklist - Please Contribute!
    My current car: 2002 WRB WRX Wagon.
    Mods: GM BCS, Carberry SD rom, uppipe, AEM UEGO, Klunk Killer, F+R shifter bushings, head unit
  9. #37
    Sep 2009
    Clearwater, FL
    I have tried, don't realy know to many people in this town that have the same car...
  10. #38
    Feb 2010
    O.O
    really? You learn something new every day . Is this tunable in any way?
