Results 16 to 30 of 38
This is a discussion on HELP ASAP!!! SILICONE INLET TUBE!!!!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I haven't been running the pill......
    Registered User Civic_jdm16's Avatar
    Sep 2009
    Clearwater, FL
    "SCHIRRA~#16" HOLY F*CK'N A$$ CRACKERS!!!!!
  2. #17
    Registered User MakeItRoar's Avatar
    Aug 2010
    Chicago, Illinois
    Well that idea goes out the window. Check the vacuum line running to your BOV. Pull it off, and plug it with your finger before starting. If you pull your finger off, and the engine sounds exactly the same, you have a leak between the BOV and the other end of that line. Honestly, at this point I can't do much more than think of things that MIGHT cause this. Roll the lines coming off the inlet and checking for cracks would be the final thing I would do before sleeping on it. This is quite the predicament.
    2006 WRX Limited -Pro-tuned VF-39, STI TMIC, STI factory I/C Sprayer, Throttle body Coolant Bypass, STI Exhaust, SPT Short Ram Intake, SPT Upper Front and Rear Strut Bar, Red Samco Radiator Hoses, STI Trunk, SPT Short Shifter, Aftermarket Rotors, Lamco Turbo Gauge, Catless Downpipe, Hella Supertones, RallyArmor Limited Edition Pink UR Flaps, 35% Tint, Grounding Mod, Walbro 255 Fuel Pump, SPT Heat Shield STI Piston Shift Knob!
    Hawk-Eye Alliance #430
  3. #18
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    it sounds like it could be a MAF problem. That's the only major thing you would have been working with that could cause that. I do see that you have an Atmospheric BOV though. Did you cap the new turbo inlet?
  4. #19
    Nov 2006
    Denver Metro Area
    Did you try pulling the battery cables off for a couple seconds and re-installing them to reset the ECU?
  5. #20
  6. #21
    Sep 2009
    Clearwater, FL
    Yes The turbo Inlet is pluged. And when I first put the intake on the maf was in backwards but its now facing the rite way and yes I took off the battery to do the ecu reset thing. But could trying to run the maf backwards damage it? no check engine light... Yea I'm going crazy tryn to figure this out!!!
  7. #22
    Nov 2006
    Denver Metro Area
    it could have skewed your readings, and you may have to reset the ECU once more.
  8. #23
    Sep 2009
    Clearwater, FL
    I reset it again after that, but would this cause damage to the maf? or cause any other damge?
  9. #24
    Sep 2009
    Clearwater, FL
    Ok listen to this!!!!!! I just got off the phone with my friend he told me to try and unplug the maf and try to run it... It starts and runs without the maf plugged in!!! so im guessing bad maf?????
  10. #25
    Aug 2010
    Chicago, Illinois
    Clean the MAF? If you've never done it, maybe it's just dirty as hell.
  11. #26
    Sep 2009
    Clearwater, FL
    Thats what Im gona try going to autozone now for cleaner...
  12. #27
    Aug 2010
    Chicago, Illinois
    Get CRC industries MAF cleaner, it's FANTASTIC. 9 bucks a can or so at Autozone, and it gets the job done extremely well.
    http://www.amazon.com/CRC-05110-Mass.../dp/B000J19XSA
  13. #28
    Sep 2009
    Clearwater, FL
    No good, I went and picked up a can of the CRC and it made a small change but I think the maf is shot..... and its like $130.00 at autozone for a new one... So Im just gona run it unplugged now for a few days untill I can go buy one.... God, My car treats me like a bad girlfriend! lol
  14. #29
    Aug 2009
    Canada/Ethiopia/Madagascar
    If it's MAF related and it started happening immediately after install it's possible you pulled a wire out of the plug. Might not be readily apparent.
    ...Rob.
    [my photos]
  15. #30
    Sep 2009
    Clearwater, FL
    Already checked the wires and cleaned the plug.... I realy think that running it backawards or switching it to the new intake tube damaged it...
