Results 1 to 11 of 11
This is a discussion on 05 WRX Is a pain to refuel, Pump clicks off almost instantly within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I bought an 05 WRX and everytime I go to fill up the pump nozzle shuts off almost immedietly. I ...
    May 2011
    Logan, UT
    I bought an 05 WRX and everytime I go to fill up the pump nozzle shuts off almost immedietly. I have tried at least half a dozen pumps around town and they all do it. It sounds like fuel is bubbling up in the neck going to the tank. If I just slightly squeeze the handle I can get it to work, but it litterally takes me 20 min to fill up my car. If there is a discussion on this already and someone can point me in that direction that would be supurb! Any help would be appreciated this is driving me nuts!
    May 2011
    Logan, UT
    Wow now I feel like a noob? Um. . . Normal ones at the gas station? haha Chevron and Phillips 66 are the two I use the most. Their fuel makes my car happy. They are the type that shut off when the tank is full if that helps.
    May 2011
    Logan, UT
    The only link that works out of the three is the p0447 code. I can't get the Fill 'er up link to work. Is it something I'm doing wrong?
    No I'm having the same problem and don't know why. I reported the post to the mods and hopefully the links can be sorted out.
    At the back of the car there is a harness leading to a canister and fill tube. Check for obstructions.
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by Bigfoot1457 View Post
    p0447 code
    But see this first:
    Fill 'er up? NOT!!!
    May 2011
    Logan, UT
    Thanks for the links. I'm hoping its just something stuck in there, I haven't thrown a code or anything. Ill let you guys know what I find. Thanks for the help!
    May 2011
    Logan, UT
    Sorry for the dumb questions, im new to subaru. But i just pulled off the cover on the side of the evap canister that has the filter underneath, is that filter supposed to be wet? It doesn't smell like gas but it is wet and some water dripped out when i took the cover off
    May 2011
    Logan, UT
    Ok i also dropped the whole canister and it feels like its full of water, and water is draining out? Normal?
