Results 1 to 9 of 9
This is a discussion on only 7 psi still ??? :((( within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have an 02 wrx with a manual boost controller and have noticed recently im only getting 7 psi no ...
    Registered User romanoodles1's Avatar
    Mar 2010
    I have an 02 wrx with a manual boost controller and have noticed recently im only getting 7 psi no matter how much gas i give it...I was thinking it is either my mbc has died or my boost solenoid died because 7 psi is wastegate pressure i believe? Is there anyway to check to see if these are the problems? Any help would be awesome
    Feb 2011
    Canada
    Could be boost leak. Check all your IC hoses with soapy water.
    Sammich Makin' Princess Leia wrxtreme06's Avatar
    May 2007
    orlando flawduh
    any other mods? how were you measuring your boost & in what gear?
    desiree
    06 impreza wrx tr
    : cobb stage II - protuned by STi_Mikey!
    hawk-eye alliance #11:11 //
    wingl3ss @ll!ance #17 // lvl 80 N.E.R.D.
    facebook
    zax
    zax is online now
    Taco Boy zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Wastegate pressure. Your MBC got done broke.
    Facebook me here
    Registered User Salica's Avatar
    Sep 2010
    Orange county
    I have the same problem.
    I have been having the same issue i have narrowed it down. but some of the steps i have tried.
    1. check for vacuum leak.
    2. check to see if the pill is still in the hose connected to the wastegate.
    Moderator Donkey's Avatar
    Da boonies
    Your running both an MBC and the stock BCS?
    2002 FORESTER S
    1998 FORESTER S
    Mar 2010
    Yes the car has a turboxs mbc and a stock boost controller solenoid....where is the pill located? It used to boost fine so i dont see how this "pill" could of just fallen out?
    Supporting Member yamaha_rider619's Avatar
    Jul 2009
    colorado is home, Kansas is the temporary home
    You are running wastegate pressure. You need to get a tune on your can and throw away (or sell) the MBC, unless you truly have the need, modications for it
    Josh
    2003 Subaru Wrx Vf39'd
    Bugeye mafia #300
    Sponsored By: WRXPro.com
    Sep 2010
    Orange county
    I found the stock boost controller was the problem in my car. I bought a new one and bam good to go.
    Of course this was after checking the vacuum lines.
    http://imageshack.us/photo/my-images/51/needn.jpg/
    i tried using the insert photo tool but i guess i dont know wtf im doing LOL...
