2000 Impreza Electric Window Motor Replacement - How?
Results 1 to 2 of 2
This is a discussion on 2000 Impreza Electric Window Motor Replacement - How? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a 2000 Impreza Sport and the Electric window of the drivers door doesnt work. I took the panel ...
    Apr 2011
    Newcastle Upon Tyne, UK
    I have a 2000 Impreza Sport and the Electric window of the drivers door doesnt work. I took the panel off to see that the problem is that the arc shaped cog that lifts/lowers the window has popped out of the motor that drives it. This is all mounted on the inside of the door frame and so I can't get into it.
    Is there an easy way to get to that so I can repair/replace the motor? I know in other cars these bits are held on with pop rivets that you can drill out and then replace afterwards.
    Administrator
    May 2003
    Quote Originally Posted by svendo View Post
    Typically only Ford and GM will rivet in the regulators. Your regulator should be held in with 10mm bolts. Lower the window by hand until you can detach it from the regulator. Push the window up, unplug, unbolt, and remove the regulator for repair or replacement.
