Off the lot Turbo Fail?? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
This is a discussion on Off the lot Turbo Fail?? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; To replace the OEM inlet with another OEM inlet the intake manifold has to be removed. If replacing with an ...
    Aug 2009
    Canada/Ethiopia/Madagascar
    To replace the OEM inlet with another OEM inlet the intake manifold has to be removed. If replacing with an aftermarket silicone one you can wrestle the replacement in without having to remove it; all the knibs/knobs etc... can be hacked off the OEM inlet before removing it so you can pull it from under the manifold. $700 is on the high side for labour however.
    ...Rob.
    Registered User redjester's Avatar
    Sep 2010
    Quote Originally Posted by mudferret View Post
    It is kind of a tedious job to replace the pipe (stock)... remove the intake, depressurizing the fuel lines, re-pressurizing and checking levels, etc.
    The labor costs are a bit steep but I think I would almost rather have it fixed at a dealership. I've only had the car for one week after running into problems. I'd like to be sure that the job is done right and this way they can check the car for potential other problems. Plus, the '04 had an open recall that I am getting taken care of.
    The Blue Goose
    Website: www.JesseEgan.com
    YouTube Channel: www.youtube.com/user/RedJester24
