Results 1 to 3 of 3
This is a discussion on Stock water tempature sensor loaction - 05 WRX within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Ive been searching for the answer - cant seem to find it. Where is the stock sensor for the water ...
    Registered User NYJets's Avatar
    Jul 2010
    NEPA
    Where is the stock sensor for the water temp on a 2005 WRX?
    Under the alternator?
    Yes upper front part of motor near the oil pressure sensor somewhat I think.
    Aug 2008
    Kennett Square, Pennsylvania
    the coolant temperature sensor is located in the coolant crossover pipe under the intake manifold.
