Best adhesive for door side mirror to plastic?
Results 1 to 9 of 9
This is a discussion on Best adhesive for door side mirror to plastic? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I was driving one of the vans (GM) we have at work, when the driver's side mirror started to shake ...
    Apr 2004
    Southeastern PA
    I was driving one of the vans (GM) we have at work, when the driver's side mirror started to shake quite a bit. I stopped, reached out to check - it pretty much fell out into my hand.
    So ... what is the best adhesive to reattach? The mirror has no silver backing - it is plain glass. The mirror housing mounting surface is your basic hard plastic.
    Mods & Pics
    Administrator
    May 2003
    Quote Originally Posted by Sasquatch View Post
    Quick set windshield urethane. Normally available at any parts store. Put it in a caulk gun and go to town. Just be careful because it's a real pain to clean if you make a mess. Glue it on, tape it together with masking tape and you're good to go the next day.
    May 2010
    Pittsburgh, PA
    That is a tough one. There are factors to consider there aside from just bonding the different materials - temp/strength/longevity (normal considerations for some of us, har har).
    I would look into a glass friendly epoxy personally. I have never used epoxy on glass, however.
    EDIT: TR has a much more credible handle on this situation. Follow his advice =)
    2011 STi Build Log
    Apr 2004
    Southeastern PA
    Quote Originally Posted by Trainrex View Post
    Thanks ... I know you would know. A caulk gun sized tube will be way too much. Does it come in smaller sizes?
    Mods & Pics
    Administrator
    May 2003
    Not that I know of. Its kind of a one use thing. Once its open it starts to harden.
    Apr 2004
    Southeastern PA
    OK, thanks.
    Mods & Pics
    Registered User Scottyb0119's Avatar
    Feb 2011
    Cleveland Ohio
    what about the 3m brand foam tape, its damn strong and provides vibration resistance.
    May 2010
    Pittsburgh, PA
    Quote Originally Posted by Scottyb0119 View Post
    I'd be concerned about hot summer days. I'm pretty sure it'd hold though... If it was my old van, heck yes 3m foam tape would work. Anything that I actually enjoy driving and want piece of mind my mirror won't fall off of, I'd say no go.
    Also, I don't know how well it would ahere to glass. Glass is a funny material.
    2011 STi Build Log
    Administrator
    May 2003
    Only when you're looking in the mirror!
