Update: Using my electronic boost controller now. No longer overboosting. Havent checked the smoking issue yet.
This is a discussion on 02 WRX With VF39 - Issues? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Okay well let me start by saying my car is a 02 with 137k miles and a 4EAT. Here is ...
Okay well let me start by saying my car is a 02 with 137k miles and a 4EAT. Here is my mods:
VF39
STI fuel pump
STI intercooler
Deatschwerks 565cc Injectors
Megan racing uppipe
Megan racing downpipe
SPT catback
Blitz Blowoff valve
Perrin Manual boost controller
AEM cold air intake
These are the mods that link up to the engine. I tried myself to put on my vf39 (had a td04 on until it wouldnt boost at all and when i took it off it had a very messed up turbine) and ran into issues with coolant and oil after i installed it and it was smoking pretty bad from not having enough coolant (it was leaking after i installed everything). So i took it down to subaru and it was one week and $1500 dollars later and my car is still smoking when i stop and smells weird. I dont know what to do next.
But i have a second issue. I was using my perrin manual boost controller before and now it doesnt work? I have it set to SUPER low and when i boost it goes into like 24 psi and throws a code.
So for advice:
What should i do about the smoking? Does not smell like oil, or coolant really, and its white smoke, not blue.
And should i go back to using my electronic boost controller? Or do you think the same issue will happen?
Thanks for anyones help!
EDIT: also im using a Cobb accessport with the map set for the mods i have like the vf39 and deatschwerk injectors. It says boost should be like 18 tappering to 16.5. Which is fine by me. I plan on getting the car tuned eventually when im not smoking and i get all these issues dealt with.
