the only thing this should affect is the oil temp gauge itself, that is if this is the factory oil temp. gauge.
This is a discussion on Remove Oil Temp Sensor 2003 wrx within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hello, I would like to replace my oil temp sensor and drain plug with one of these. QuickOilDrainValve.com - the ...
Hello, I would like to replace my oil temp sensor and drain plug with one of these. QuickOilDrainValve.com - the best way to change oil my question is if I remove the sensor will it cause any downstream issues? (engine lights or anything other than my oil temp gauge not to work)
Thanks!
Thats the one. Thanks EvoEatr!
