Results 1 to 5 of 5
This is a discussion on What are the symptoms of boost surge? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Maybe im just a bit paranoid, but this morning i was going onto the highway from the on ramp, and ...
    Registered User WillieRX's Avatar
    Nov 2010
    CO Mountains
    Maybe im just a bit paranoid, but this morning i was going onto the highway from the on ramp, and i am not being aggressive in my driving or accelleration. I knoticed that my car "felt" like it has having some instantaneous "hard pulling". It felt like for maybe 1 second increments, the car was pulling hard, then lets off (almost like hitting bumps on the road, but peing pushed forward by them very briefly). My pedal was around 25%. It did this too me maybe the higher gears (4th and 5th). It didnt do this constantly either, only intermittently. It also seemed to occur more often when going uphill. Engine RPMs are not fluttering at all either.
    Car is Stage 1 OTS tune with only CBE and drop-in panel filter. Maybe im not used to how the stage 1 operates typically because im so used to the economy tune on my commute. Didnt knotice this issue last night when driving throw the mountain roads either, and babied the throttle still.
    Again, maybe im just paranoid and will plug in the cobb and observe boost levels as im driving this afternoon. One thought is the altitude sensor adjustments. On a weekend basis i drive from around 5,500 ft to 9,000+ ft one day, and the reverse coming back for the weekdays. So, maybe the sensors are readjusting to learn the parameters of the air at 5,500 ft.
    2006 Subaru WRX TR (Weekend Warrior)
    1993 Ford F250 Diesel (Daily Work Commuter)
    Hawk-Eye Alliance #9455
    My WRX Mods
    Apr 2007
    8000' up in Colorado
    That sounds like boost surge, or like a clutch slipping. I'd like to see what the AP shows for the boost levels.
    Scott
    Nov 2010
    CO Mountains
    Hmm, i really hope its neither and just my imagination, ill hopefully get accurate results this afternoon and post them tomorrow morning...
    Not sure about the clutch, doesnt slip when I accellerate from a stop (normal or performance driving).
    I have had a similar symptom in my vette a while back. When i first got my vette, it was completely stock. However, whenever i was in 4th, 5th, or 6th gear and i applied the gas pedal, the car would "clunk" quite aggressively and felt like i was going nowhere fast. Originally i thought it was the clutch screwing up on me as well. But, i decided to give it a well needed tune-up (New Distributor, Spark Plugs, Wires, Coil) And the problem disappeared on it, guess was a ignition problem on that car. I am feeling similar "lurches" in the subie, but not even close the extent that the vette gave me.
    My WRX Mods
    Apr 2007
    Clutch slip shows up in the higher gears, especially going uphill. It normally doesn't show up from a start until the clutch is really really bad.
    Scott
    Nov 2010
    CO Mountains
    Well, Observed boost/vacuum levels on both trips. Nothing out of the ordinary. So, that rules out boost surge. Also, clutch doesnt seem to be slipping either.
    Im thinking its just me hitting a couple of bumps on the road that made the car feel a bit funky or catching some wind interference from cars in front of me etc..
    Another suspicion again is ignition related. Maybe needing some new spark plugs. Not sure if previous owner changed them or not.
    My WRX Mods
