Find and repair the leak
This is a discussion on radiator problem within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey people, This is maybe a normal topic,but today I noticed my coolant was spraying out of somewhere, on my ...
Hey people,
This is maybe a normal topic,but today I noticed my coolant was spraying out of somewhere, on my gauge my temperature was normal but when I opened my Hood there was wet spots every Where (Coolant was spraying out of somewhere ) but. My temperature stayed the the same. Should I replace the radiator? I know Its leaking because I can see smoke from the Hood bit temperature stays the same
Josh
2003 Subaru Wrx Vf39'd
Bugeye mafia #300
Sponsored By: WRXPro.com
It most likely has a very fine crack between the upper rad hose and the filler neck. Cheap route is to repair it or spend some cash and replace it. Plastic endtanks are pretty lame and will most likely crack again. I picked up an aluminum Mishimoto rad when mine cracked. Got it on amazon.com for around $250ish.
I know its been weeks but thank for the advice finally got a job and was able to buy a new radiator
Hopefully the leak was actually in the radiator.. I would have identified the source of the leak first. It would suck to replace your radiator only to realize that it was a pin hole in a hose that was the source of the leak the whole time.
