Turboback with a custom reflash
This is a discussion on Throttle response within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have an 08 wrx hatch that's stock, Idk if it's me but the response seems slow as hell. Is ...
I have an 08 wrx hatch that's stock, Idk if it's me but the response seems slow as hell. Is that how these cars are? If not how do I fix it??
It's called turbo lag. Have you had a turbo car before?
Scott
hmm, 2 things:
#1: you may be having turbo lag issues. If you're just going along at 2k, flooring the gas pedal will do almost nothing at first, until your turbo spools. Try the same up near 4k and you should instantly shoot off.
#2: DBW. Your car is DBW, and thus, instead of a cable connecting your foot and the throttle, you have a complex algorithm. It sucks, especially when the algorithm is bad (as most find it stock). A reflash will give you better pedal feel (pedal input to engine output comparison)
My big thread: The Used WRX Buying Checklist - Please Contribute!
My current car: 2002 WRB WRX Wagon.
Mods: GM BCS, Carberry SD rom, uppipe, AEM UEGO, Klunk Killer, F+R shifter bushings, head unit
Make sure you're not looking for a throwing response if you're doing 35mph in 5th gear.
Higher revs=boost zone=boost=response
2006 WRX Limited -Pro-tuned VF-39, STI TMIC, STI factory I/C Sprayer, Throttle body Coolant Bypass, STI Exhaust, SPT Short Ram Intake, SPT Upper Front and Rear Strut Bar, Red Samco Radiator Hoses, STI Trunk, SPT Short Shifter, Aftermarket Rotors, Lamco Turbo Gauge, Catless Downpipe, Hella Supertones, RallyArmor Limited Edition Pink UR Flaps, 35% Tint, Grounding Mod, Walbro 255 Fuel Pump, SPT Heat Shield STI Piston Shift Knob!
Hawk-Eye Alliance #430
Port and polish everything. Then get tuned.
Why do you say port and polish?
Scott
Scott
Chudv23, what car did you drive prior to your 08 WRX?
I went from a 2002 Civic Si to 11 WRX and the throttle response seems comparable to me.
I agree that below 3,000 RPM the engine is tepid but I rather like that; I loaf around the neighborhood shifting at 2,500-3,000 keeping it comfortable and smooth (and probably saving fuel). Then when I have some room to run, I keep the RPM above 4,000 and it's a lot of fun.
