Results 1 to 8 of 8
This is a discussion on Wideband trouble within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; My AEM uego wideband has been pegging from lean to rich continually, while driving normal and WOT. I am thinking ...
    Registered User aaron-98's Avatar
    Jul 2008
    Byesville, Ohio, United States
    Wideband trouble
    My AEM uego wideband has been pegging from lean to rich continually, while driving normal and WOT. I am thinking the sensor is bad. Any ideas?
    Jul 2008
    Anyone?
    Registered User poly_poly-man's Avatar
    Feb 2010
    Rochester Institvte of Technorcery
    what's the CEL for?
    My big thread: The Used WRX Buying Checklist - Please Contribute!
    My current car: 2002 WRB WRX Wagon.
    Mods: GM BCS, Carberry SD rom, uppipe, AEM UEGO, Klunk Killer, F+R shifter bushings, head unit
    Jul 2008
    Wastegate solenoid. I'm assuming it's on because I have a mbc.
    Feb 2010
    *probably* just a dud sensor or a bad connection somewhere.
    Are you tuned? I can't really recommend having an MBC, but if you're satisfied with the results, and your turbo is happy and everything, you may just want to adjust the fuel map a little and definitely disable that DTC.
    Moderator Donkey's Avatar
    Da boonies
    2002 FORESTER S
    1998 FORESTER S
    Apr 2007
    8000' up in Colorado
    What is the year/mods/mileage on your car?
    Scott
    Jul 2008
    It's a 2002 wrx with 148k miles. I have a vf39, sti pinks, 255 pump, catless uppipe/turboback. And yes I am tuned, at 15psi. I have a hallman mbc.
    It runs great, no problems whatsoever. The sensor has only been installed for about 10k miles. I checked the connections and all seemed fine. I ordered a sensor today; so i will go from there. It is acting similar to the video that Donkey posted.I will have my tuner double check the tune for safe measure.
