The cap could have been loose. In any case I'd replace the cap, top off the coolant, and thoroughly burp the system to ensure no air pockets.
This is a discussion on Please help! Coolant problem! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So I changed my coolant a week ago, I used subaru coolant and conditioner. Then today I was driving home ...
So I changed my coolant a week ago, I used subaru coolant and conditioner. Then today I was driving home and coolant exploded every where while driving it was coming out of the cap located closest to the strut tower. I have a 2002 subaru wrx turbo. I'm trying to figure out what would cause this to happen.![]()
The cap was definitely tight I competed in an autocross event after changing my fluids and never had any problems. I checked every thing twice. I thought I burped it pretty good. Could it be a bad thermostat?
I would think the hoses would seep before the cap itself seemingly failed. Since you are going to burp again anyway, ensure you have circulation -- carefully! -- by simply looking at the coolant after the fans come on but while the cap is still off. On mine I can clearly tell when the thermostat opens.
Check the reservoir for any cracks or cracked tubing.
