Results 1 to 8 of 8
This is a discussion on Blown turbo? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have no clue whats going with my car at all. It will barely hit 5 psi and runs extremely ...
    Feb 2010
    Fort Worth, Tx
    Blown turbo?
    I have no clue whats going with my car at all. It will barely hit 5 psi and runs extremely rich when boost should kick on 8.5 to 9 from 2500 to 3000 rpms to be exact. No I do not have a vta blow off valve yes it is aftermarket but is recirculated. The mods I have are turboxs uppipe, turboxs tbe, cobb ap v2, greddy fmic, with a pdx tuning stage 2 cobb map tuned for a fmic, and a hks ssqv. Everything has been running good up until now. Any answers will be deeply appreciated.
    Toboggan T0rque's Avatar
    Dec 2004
    Your Mommas
    an hks ssqv is not a recirculating blow off valve.
    Lead Wrench @ WTF Tuning, LLC
    Dec 2004
    Your Mommas
    what does your car tell you is wrong? As in... What CELs are coming up?
    Feb 2010
    Fort Worth, Tx
    Thats just it there is no codes or any cel.
    Feb 2010
    Fort Worth, Tx
    Also an hks ssqv is a recirc when you put the recirc fitting in it which is what I did.
    Moderator Donkey's Avatar
    Da boonies
    Could be a boost leak.
    2002 FORESTER S
    1998 FORESTER S
    Registered User yawnoC's Avatar
    Mar 2011
    Berwyn, PA
    I am by no means any kind of expert, but that sounds like a boost leak to me. If the turbo is blown, then you're most likely going to hear some problems with it before.
    Feb 2010
    Fort Worth, Tx
    It was a major boost leak one of my intercooler couplers had a hole in it about the size of a pinky. From when it busted off my intercooler just didn't notice it cause it was at night when I was trying to fix it. Went and bought a new vibrant coupler put it on and works perfectly know. Probably going to go by all new vibrant couplers and replace all of them. So I don't have to worry about anymore blowing apart on me again. Thanks for the input guys really appreciate it.
