Seafoam Poll
Results 1 to 15 of 16
This is a discussion on Seafoam Poll within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Who uses it? If you use it, what'd you do with it? What were your results (positive or negative and ...
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Seafoam Poll
    Who uses it?
    What were your results (positive or negative and why)
    What Year and Model car?
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    Aug 2008
    Kennett Square, Pennsylvania
    I have used it on my Legacy and my Outback and have had phenomenal results with both of them. In my opinion there are very few products out there that you can say " WOW this really works" and seafoam is one of them. 96' Legacy and 00' Outback, havent had a need to use it on the WRX yet considering the motor only has around 15k miles... OH vacuum induction and fuel induction on both of them...
    Registered User MakeItRoar's Avatar
    Aug 2010
    Chicago, Illinois
    I use it!
    Vacuum lines, oil, and gas! Tri-fecta, you betcha.
    Positive. Smoother idle, less shaky first gear when i let the idle carry me through parking lots, etc., and cleaner oil when I change it.
    2006 WRX Limited
    2006 WRX Limited -Pro-tuned VF-39, STI TMIC, STI factory I/C Sprayer, Throttle body Coolant Bypass, STI Exhaust, SPT Short Ram Intake, SPT Upper Front and Rear Strut Bar, Red Samco Radiator Hoses, STI Trunk, SPT Short Shifter, Aftermarket Rotors, Lamco Turbo Gauge, Catless Downpipe, Hella Supertones, RallyArmor Limited Edition Pink UR Flaps, 35% Tint, Grounding Mod, Walbro 255 Fuel Pump, SPT Heat Shield STI Piston Shift Knob!
    Hawk-Eye Alliance #430
    Aug 2009
    Canada/Ethiopia/Madagascar
    I don't use it, gas is a lot better than it used to be. I will typically run Redline SP1 through the system once a year however. Perhaps at some point I will, but not yet.
    My wife used to moonlight as Seafoam's accountant when she lived in MN.
    ...Rob.
    Registered User poly_poly-man's Avatar
    Feb 2010
    Rochester Institvte of Technorcery
    I'm planning on doing it soon (when it warms up a bit - I'll be doing an oil change right after).
    My plan is to split the can in thirds - one for the vacuum line, one for the oil, and one for the gas tank. I'll do the right procedure for the vacuum one, run it around the block twice (a couple miles), and do the oil change.
    My big thread: The Used WRX Buying Checklist - Please Contribute!
    My current car: 2002 WRB WRX Wagon.
    Mods: GM BCS, Carberry SD rom, uppipe, AEM UEGO, Klunk Killer, F+R shifter bushings, head unit
    Jan 2005
    Canada B.C.
    I used it in my '02 WRX 1/3 in gas tank and the rest in vac line off the BPV... Seemed better than before but maybe that was just wishful thinking... Not as much smoke came out as I thought was going to, but my engine was in perfect running condition with 300,000KMs/187,500Miles.
    '02 WRX 4EAT, 311,000KMs/194,500Miles, Sold. Best car I ever had. '09 STi stage 1, hope this one will be good too...
    Aug 2010
    Chicago, Illinois
    Quote Originally Posted by poly_poly-man View Post
    Make sure you have the right proportion of seafoam to gas since you're going by thirds of a can. There 16 oz. in a can, so make sure you have between 5-6 gallons in the tank!
    Registered User metaldahlberg's Avatar
    Sep 2010
    NH
    I put some in my gas and some through my bpv vacuum line on my 2010 before my tune. Not a huge amount of smoke came out so probably didnt do a whole lot. But I know a lot of people who use it on older cars and like it.
    Contributing unsolicited, worthless opinions since 9/10...
    The project I spend all my money on.... <---- Click it
    Registered User WillieRX's Avatar
    Nov 2010
    CO Mountains
    I use it as a maintenence item for my cars. I pour a can into the tank every 10,000 miles or so and on occasion directly introduce it into the intake manifold, but never let it pool in the cylinders.
    I would never pour it in my crankcase though. I have a friend who was part of the TRG race team and now a mechanic for exotic cars and he warned me how the seafoam slowly ruins your gaskets and seals in the engine block.
    2006 Subaru WRX TR (Weekend Warrior)
    1993 Ford F250 Diesel (Daily Work Commuter)
    Hawk-Eye Alliance #9455
    My WRX Mods
    zax
    zax is online now
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Seafoam is the shiz!
    I use it through my vacuum lines, in my crankcase (right before an oil change), and in my gas tank
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    The Fruit mangostick's Avatar
    Oct 2009
    VB VA .. the ghetto on the sea
    I've used it in various applications.. works efffin awesome. Seriously, I'm usually very skeptical of anything in a can that says it fixes things... but that stuff works on everything I've put it in.
    Only drawback.. it smokes like hell for a little while as its cleaning off the carbon. My x's first honda was a trainwreck and after dumping that stuff in there it started gaining in power and fuel mileage. I was shocked but instantly converted.
    so far I've used it in
    stock 86 merkur (2.3l turbo) via fuel system and vac lines
    89 honda accord via fuel system and vac lines
    00 honda accord v6 via fuel system
    04 Chevy impalla 2.4l 4cyl (g-parents car, never driven hard, rarely up to op temp) via vac lines and fuel system
    early 90's Troybuilt lawn mower (briggs engine) via fuel system
    99 honda 400ex via fuel system
    In the worst ones (89 honda and the 86 merkur) I noticed a huge improvement in driveability and Idle quality.. also saw fuel mileage and response improvement in the honda. I always drove the merkur like I stole it so I cant really say anything about fuel mileage on that. My lawn mower is easier to start now and seems to last longer on a tank of fuel and idles better. The only one I didn't see any improvement on was the honda atv.. I'm thinking it was purely because I always ran the dog piss out of it and rarely ran it out of op temp and I bought it new so it was always well taken care of.. at least until it was stolen. lol.. after that I cant tell ya, but I hope it blew up and injured the thieving rider. Barstarp!
    anyhow, I digress.. its a great product and one of the very few I'd actually say does exactly what the advertising hype says it will do. I've never put it in a crankcase though.. I'm just a firm believer in good quality high detergent oils and regular maintenance. If you're using the right oil and changing it when you're supposed to you really shouldn't need to "clean" the crankcase. Not with modern oils anyway.
    OBP 2010 5dr *traded*
    SWP 2013 FRS
    SUCH IS MANGO!
    Registered User shadowpr's Avatar
    Jan 2011
    TX, NY
    Ok, what is this stuff, and is it recommended for newer cars?
    Administrator
    May 2003
    It's good for cleaning a little sludge out of the intake tract. It's good for cleaning a little bit of deposits from injectors. It's VERY bad to dilute oil with ANY type of solvent. Especially on a 2.5 with an already weak rod bearing setup.
    Feb 2010
    Quote Originally Posted by Trainrex View Post
    The idea I got was that you run it in with the oil for only about 5-10 miles before you do an oil change. The solvents have time to work, and it doesn't wreck your engine.
    @shadowpr: I think the stuff is mostly liquefied styrofoam, actually - look it up if you're interested in the chemicals . There's really no reason to run it on a new car, because it won't have many carbon deposits to get rid of. You can do it, but it'll probably be a waste. In a few years, it'll be great for your car.
    Administrator
    May 2003
    I understand the theory, but the problem is in the execution.
    A crank bearing will last approx. 3 seconds when starved for oil. With oil diluted with solvents, they will last a little longer, but the chances for damage are extremely high.
