Results 1 to 4 of 4
This is a discussion on Engine Refresh within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Does anyone know if its possible to rebuild an oil pump and power steering pump on a 2004 sti? Or ...
    Jul 2010
    Hookedonphonex
    Engine Refresh
    Or is it cheaper to just buy a new one? power steering pumps looked pretty pricey..
    I have seen seal kits for the PS pump for 2.0L motors but do not know if they fit the 2.5L units. If your pump is the same, they will of course. It will be simpler probably to find a used pump from a wreck and use the whole pump instead. I don't know about the oil pump.
    Jan 2005
    Eh, whaaaaa?
    Why are you needing a new oil pump? If you are in need of one, you may have more problems than you realize...
    Cody
    Jul 2010
    Hookedonphonex
    I dont need an oil pump. I just heard they often fail.. so while i have my car apart i might as well replace it.
