Rod knock on my 02 bugeye
Results 1 to 7 of 7
This is a discussion on Rod knock on my 02 bugeye within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Just got alot of engine work done. Turbo inlet tube, up pipe, tgv delete, new water pump, pulleys and belts, ...
    Jan 2011
    Michigan
    Just got alot of engine work done. Turbo inlet tube, up pipe, tgv delete, new water pump, pulleys and belts, fuel pump, cobb accessport and a custom tune. Now after all this is done me and my buddy realize there is a rod knock and im going to need a new engine block. Does anyone have an estimate on what this will cost with labor and if its even worth doing????
    Aug 2009
    Canada/Ethiopia/Madagascar
    Blocks can be had for cheap for an OEM one from an online vendor 2-2.5k; labour varies a ton.
    It will be much cheaper if you don't drive the car until then however, then you won't risk more damage: heads, turbo, etc...
    ...Rob.
    Are you sure it's rod knock? You're in a cold climate and piston slap, especially when cold started, is not abnormal.
    If it is rod knock, first figure out what went wrong before investing. Short blocks are available below $2K depending on shipping. Labour varies regionally.
    Aug 2009
    ^ good point, aside from piston slap there are other things that can mimic the sounds of rod knock; bad timing belt bits, cracked coil pack, I'm sure there are others.
    ...Rob.
    Jan 2011
    Michigan
    well everything has just been serviced the only other thing i could think of is its coming from the trans maybe .....would piston slap possibly cause a blown engine in the near future?
    Jan 2011
    Michigan
    it is a clicking noise ....VERY noticable around 3 thousand rpm
    Feb 2010
    SL,UT
    When you replaced your timing belt, did you chalk the pulleys to make sure nothing slipped?
    Hawk-Eye Alliance #801
