Results 1 to 11 of 11
This is a discussion on Hesitation / loss of power - 2010 WRX within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hello members, Recently, I've noticed once boost is up past 3k, it seems power has slightly been reduced. It feels ...
    Registered User soobie's Avatar
    Jan 2011
    BC Canada
    Hello members,
    Recently, I've noticed once boost is up past 3k, it seems power has slightly been reduced. It feels like I'm feathering the gas but it's always WOT. I've been using 92+ octane. The car is 100% unmodified, 25,000 kms (~14k miles). It's being dropped off at the dealership Wed, but would like to get some input as to what may have caused this loss of power.
    No codes, no smells....
    I also know it's not pyschological (some people say you get used to the power, and crave more lol)
    Thank you!
    2006 Subaru WRX Rally Blue
    1998 Jeep XJ
    1972 Ford Gran Torino 351CJ-4V
    Aug 2008
    New Berlin, WI
    Given that your car is relatively new, I would guess it's one of two things:
    1) Fuel injector jets might be a little clogged. Do you run a bottle of cleaner through the fuel system every 3,000 miles or so? If not, I recommend it.
    2) Air filter might be dirty. Simple to change.
    When you stomp on the pedal and don't get the turbo boost you experienced when the car was new, it's probably a fuel/oxygen ratio issue. Try the simple and inexpensive trouble-shooting first. If the problem persists after the two ideas above, then maybe something more serious is wrong with a sensor somewhere. Your car is still under OEM warranty, so it's shouldn't drain much of your wallet.
    Good luck.
    Jan 2011
    BC Canada
    Thanks for the tips. I haven't run any cleaner as of yet, I've only had the car for roughly 1000km (400 miles). Thus, I don't know what brand gas the previous owner (who kept it literally in MINT shape), used.
    I'll try the cleaner now that its a good time as the tank is nearly 1/4.
    The air cleaner WAS dirty, but I was experiencing this issue a week after I changed it.
    Thank you
    D
    1998 Jeep XJ
    Apr 2007
    8000' up in Colorado
    Could be any number of issues. I'd think of a dirty MAF or a boost leak first.
    I'm always curious why people under warranty worry about things like this though. If anything, wait until the dealer gives you a diagnosis and then post back what they say.
    Scott
    Jan 2011
    BC Canada
    I just wanted a few more opinions before I took it in. Not worried at all
    I'm also going to try the MAF cleaner tomorrow
    1998 Jeep XJ
    Aug 2008
    New Berlin, WI
    Teflon,
    I'm not challenging your comment. I'm trying to learn. If the MAF sensor was dirty, would it show as a problem code on an engine analyzer? Would the "Check Engine" light on the dashboard? Where is the MAF sensor on the WRX? Is it easy to clean as a DIY task?
    Thanks.
    Aug 2008
    New Berlin, WI
    Please disregard. I searched and found the answers to my MAF questions.
    Jan 2011
    BC Canada
    It's going in tomorrow and I'll let you guys know what it was.
    1998 Jeep XJ
    Aug 2009
    Canada/Ethiopia/Madagascar
    Quote Originally Posted by soobie View Post
    Not sure how similar the 2010 MAF is to previous years but make sure to clean the actual MAF sensor (hidden up in the tube) rather than just the IAT sensor.
    ...Rob.
    [my photos]
    Jan 2011
    BC Canada
    Good idea mudferret.
    Subaru dealership suspects an ECU problem, but will connect a boost gauge next week to confirm.
    Now that I have it back, I'm going to clean the MAF and IAT.
    D
    1998 Jeep XJ
    Apr 2007
    D
    Be careful what you do with a car under warranty. If they see the screws on the part have been removed, they may deny things. Just let them figure it out rather than trying to fix it yourself.
    Scott
