a few questions
Results 1 to 10 of 10
This is a discussion on a few questions within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I just installed a bunch of bushings. The trans mount, engine mount, rear diff inserts, subframe inserts, cross member bushings, ...
    Registered User shadowpr's Avatar
    Jan 2011
    TX, NY
    a few questions
    I just installed a bunch of bushings. The trans mount, engine mount, rear diff inserts, subframe inserts, cross member bushings, etc.
    The car feels like it has more power. The shifts are better. Should the car feel a little more sensitive/less forgiving when letting out the clutch? Should I expect the new sound to be a lot more aggressive?
    My other question / concern is that after having the car on jack stands for a little over 2 weeks, the battery died and went bad. No big deal, I got a new one. But now when I start the car, it sounds like it struggles, and seems louder. Any idea what this could be?
    BTW, 2009 wrx
    Jan 2011
    TX, NY
    anyone?
    Aug 2008
    Kennett Square, Pennsylvania
    I am assuming these are upgraded parts? If so usually the companies make the trans mount and motor mounts alot stiffer, so you will feel alot more engine vibrations and such as a result. ( I have driven numerous cars with these upgrades and it is def. noticeable ).
  5. #4
    Jan 2011
    TX, NY
    yeah, i'm getting used to that noise.
    the other noise that is still weird is when i start the car. it sounds like it struggles to turn on.
  6. #5
    Apr 2007
    8000' up in Colorado
    The new bushings should have zero effect when turning it on.
    But everything else should feel better.
    Scott
  7. #6
    Registered User MakeItRoar's Avatar
    Aug 2010
    Chicago, Illinois
    Quote Originally Posted by shadowpr View Post
    If it's cold out, your oil thickens and the starter struggles a bit to spin the rod, making it sound like a weak start up. Try keeping it in a garage?
    2006 WRX Limited -Pro-tuned VF-39, STI TMIC, STI factory I/C Sprayer, Throttle body Coolant Bypass, STI Exhaust, SPT Short Ram Intake, SPT Upper Front and Rear Strut Bar, Red Samco Radiator Hoses, STI Trunk, SPT Short Shifter, Aftermarket Rotors, Lamco Turbo Gauge, Catless Downpipe, Hella Supertones, RallyArmor Limited Edition Pink UR Flaps, 35% Tint, Grounding Mod, Walbro 255 Fuel Pump, SPT Heat Shield STI Piston Shift Knob!
    Hawk-Eye Alliance #430
  8. #7
    Jan 2011
    TX, NY
    no garage.
    hopefully once it warms up, it will sound better when starting up.
  9. #8
    Registered User Civic_jdm16's Avatar
    Sep 2009
    Clearwater, FL
    Batteries are listed by (CCA) wich stands for cold cranking amps. be sure to look on the battery to see what the (CCA) is. Im not sure what it should be but any local auto parts store could tell you what it should be. If the weather is cold it could make starting slugish..
    "SCHIRRA~#16" HOLY *****'N A$$ CRACKERS!!!!!
  10. #9
    Jul 2010
    Cincinnati
    I did notice with the upgraded pitchstop mount that the starter noise is much more pronounced, could be the same with upgraded engine and trans mounts, I don't have them yet so I'm not sure but that could be what the OP is experiencing
    Stink eye mob #727
    2011 WRX DGM Hatch, Protuned Stage 1
  11. #10
    Jan 2011
    TX, NY
    I also upgrade the pitch stop, so that might be it.
