2004 OEM radiator is failing. How long do I have to replace? - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 38 of 38
This is a discussion on 2004 OEM radiator is failing. How long do I have to replace? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Originally Posted by SD_GR could you use a modified retainer bracket? The one from Subaru has a fixed screw hole ...
  1. #31
    Apr 2004
    Southeastern PA
    could you use a modified retainer bracket? The one from Subaru has a fixed screw hole on the car side and a "wobble" fitting (I don't know how to say it) on the rad side, and it only bolts onto the car side. Could you grab a spare bracket and experiment with a different hole placement? Just throwing out ideas.
    What is this modified retainer bracket? I'm not familiar with it.
    I did not realize it until yesterday the Koyo core is substantially thicker than OEM.
    Edit: I just measured them; OEM = 27mm, Koyo = 53mm.
    Mods & Pics
  3. #32
    I was thinking you could buy a spare set of brackets and drill "oval" holes to allow you to tilt the rad away from the car if need be. Just a thought.
  4. #33
    Moderator Donkey's Avatar
    Da boonies,Va
    Quote Originally Posted by Sasquatch View Post
    Yes, but am unsure about the lower 160 degree spec.
    I run a 160 degree thermostat but I also run 1.3 bar radiator pressure. I don't have any issues in the winter with the car running to cold (172-180 operating temps) but warm up time is slightly longer.
    2002 FORESTER S
    1998 FORESTER S
  6. #34
    Apr 2004
    Southeastern PA
    Great idea!
    Mods & Pics
  7. #35
    Jan 2010
    Loganville, GA
    Don't most new(er) tstats fail "open" anyways? Just curious.....
  8. #36
    Quote Originally Posted by dttruax View Post
    The OEM thermostat seems to fail closed, at least according to the makers of a replacement thermostat designed to fail open (and also designed to cost... $70, which is why I never bought one and never will). I've not heard about that T-stat in years though, don't know if they are still around.
  9. #37
    Da boonies,Va
    Motorad makes a failsafe one for Subaru that runs about $20
    2002 FORESTER S
    1998 FORESTER S
  10. #38
    Jan 2010
    Loganville, GA
    Since they can be had that cheap was why I was wondering if most OEM thermostats would operate the same way. Would make sense to me. Of course that doesn't mean anything with my 2004 car....
