Any modifications, or is your car stock?
This is a discussion on Help with Check Engine light...... within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I want to know what the problems could be P0171 Fuel trim malfunction (A/F too lean)(Bank 1) P0442 Evaporative emission ...
P0442 Evaporative emission control system malfunction
P0301 Cylinder 1 misfire detected
P0302 Cylinder 2 misfire detected
P0303 Cylinder 3 misfire detected
P0304 Cylinder 4 misfire detected
What steps need to be taken to fix this...
"SCHIRRA~#16"HOLY F*CK'N A$$ CRACKERS!!!!!
One piece header I know there is a crack in it, Short ram intake, 3 inch turboback, & a 255lph fuel pump
Then your car needs to be tuned, that is your problem. It is unsafe to run those mods without a tune, period.
(you should get the crack fixed before the tune obviously, but I wouldn't drive the car at all until both are done)
Well the car is tuned, I have a new manifold one the way. I have no choice but to drive the car rite now![]()
What kind of tune does the car have?
That isn't a great set of mods to have on the car. I have no idea why you'd upgrade the fuel pump, and the short ram intake is just hurting your power by sucking in hot air.
Scott
Are the test connectors plugged in? If so unplug them.
Fix the header crack, then see which of the CELs go away.
Ok all the check engine lights are out.... My new issue is the car will not boost above 6 psi.. No leaks that I can find anywhere... Also my valves are white! Beside tempatures hotter than the devil's d*ckwhat could cause this to happen?
I noticed this when changing the manifold and putting on the new up pipe..
How many miles? The white valves could be due to oil consumption, cumulatively, and I'd guess that if the motor has seen a few miles it's to be expected. The chamber looks like it's got deposits that to my VERY untrained eye imply you're not running lean; again, don't waste too much time with what I have to say, I'm posting mostly thoughts and hope someone that actually understands this stuff sees the thread. My guess is ash from oil use over the years and if you are not heavily modded and/or have not run lean I'd not worry.
BTW, a worrisome lean would show up in the spark plugs too I'd think.
EDIT: Just saw top of thread again, and see you're modded and tuned. I'd look at the logs and check EGTs -- but white valves are not unheard of. White plugs plus white valves I'd think lean for sure though.
Ok well the car has 120,000 miles on it.. The motor doesn't realy use any oil in between changes but I do run oil stabilizer in it... but other than the valve issue what could cause the low boost?
A mechanical connection fault could also cause low boost. Get an idea of the quality of the tune though to be certain of motor longevity.
Ok... well what im realy wondering is what could go bad, or where could an unexpected leak be found.. all the vacum lines are in the proper places. im not getting any leaks from the engine to the turbo or from the turbo to the throttle body.... Will an engine that has 120,000 miles on it there could be many differnt things wrong.. but being that the car seems to be running fine expecpt for the boost.. I can't help but wonder if it may be the turbo its self or possibly even the waste gate....
Ok... Could you plz tell me what an "IAM" is ??
