driving like that in my 09 will definitely lower my mpg.
This is a discussion on could just be me, need opinions..MPG within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; hey guys, went on a long drive yesterday and I just felt like my car was guzzling gas..I was driving ...
hey guys, went on a long drive yesterday and I just felt like my car was guzzling gas..I was driving aprox. 73-75 mph and was running at about 3500 rpm's. is this normal? just felt like my tank was gone in no time..just want your guy's opinion/experiences..thanks a lot
Try doing the mpg calculations. Driving like that will lower your mpg. Do the calculations to see what works and what doesn't, and how bad you're doing.
My big thread: The Used WRX Buying Checklist - Please Contribute!
My current car: 2002 WRB WRX Wagon.
Mods: GM BCS, Carberry SD rom, uppipe, AEM UEGO, Klunk Killer, F+R shifter bushings, head unit
Ya. At 3500 rpms you are definitely in boost. Cruising at that speed will reduce mpg a lot. If I want good gas mileage in my 2010 I stay below 3000 rpms
Contributing unsolicited, worthless opinions since 9/10...
The project I spend all my money on.... <---- Click it
Were you in 4th or 5th gear?
Hawk-Eye Alliance #801
Yes... you need engine management for engine modifications
http://www.clubwrx.net/forums/tuning...ne-mods-6.html
See what the ratio of rpm to mph is.. My car runs best on around 65mph or so at around 2800 rpm.. If I get up to 70, I hit about 3k rpm.. However to 75 its like 3500 rpm.. So the difference there is quite substantial..
But that's just my two cents on that.. (more like penny and a half actually)
'88 Sub Justy *Rock in oil pan killed on freeway
'87 Honda Civic *Bad pistons (to lazy to fix)
'85 Nissan 200sx *Blown engine drifting
'00 Sub Outback *Mother literally stole
'92 Toyota Tercel *Hated it
'02 WRX '07 kawasaki ninja. * current
For me, below 3k and I get ~24 mpg. Anything above that, I get 20 sometimes lower if I'm feeling spirited.
Sent from my Evo 4G using Tapatalk
Wow what year is your car?
I never realized a WRX would be at 3500 rpm at that speed. It badly needs an overdrive. Glad I have a 6 speed at 80 I'm at 3000.
Scott
Isaac -- 2003 WRX sedan Stg II
He who shall be last, shall be sideways and smiling... - Jeremy Clarkson
don't want to have to quote all of you so I'll just answer them all aha
but it's an 05, and I was definitely in 5th gear. I was surprised myself how high the rpm's were...to stay below 3k I have to be going like 65mph or less..just seemed weird to me, didn't know if anything mechanically could be wrong..or if that's just how it is. guess I'll have to drive like a grandma to save gas :/
Do you know the history of the car? The gear ratio does not seem stock.
Post speeds at specific rpm for each gear and ask other members with the same model to compare.
The six speed has closer ratios, but the same final drive and STi 6th and WRX 5th have nearly the same ratio (0.756:1 6MT and 0.738:1 5MT). In short, 80mph in 6th should be the same revs as 80mph in 5th on the WRX.
This. Boost depends on load, not RPMs.
Facebook me here
Originally Posted by Mikie13
