Green fluid leaking in engine bay
Results 1 to 12 of 12
This is a discussion on Green fluid leaking in engine bay within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; any ideas what the problem is...
    Jan 2011
    JAPAN
    any ideas what the problem is Click image for larger version.
    Feb 2010
    SL,UT
    Your leaking coolant from somewhere... trace the leak and replace the bad part accordingly...
    Hawk-Eye Alliance #801
    Registered User MakeItRoar's Avatar
    Aug 2010
    Chicago, Illinois
    Coolant? Check the cap, if it is cracked or not making a seal, perhaps the heat is causing the coolant to come out of the reserve.
    Didn't refresh in time to see below, but coolant is confirmed. Check the cap and seal on the tank.
    2006 WRX Limited -Pro-tuned VF-39, STI TMIC, STI factory I/C Sprayer, Throttle body Coolant Bypass, STI Exhaust, SPT Short Ram Intake, SPT Upper Front and Rear Strut Bar, Red Samco Radiator Hoses, STI Trunk, SPT Short Shifter, Aftermarket Rotors, Lamco Turbo Gauge, Catless Downpipe, Hella Supertones, RallyArmor Limited Edition Pink UR Flaps, 35% Tint, Grounding Mod, Walbro 255 Fuel Pump, SPT Heat Shield STI Piston Shift Knob!
    Hawk-Eye Alliance #430
    Jan 2011
    JAPAN
    well one thing i forgot to mention the cars knock and tps sensors are waiting for there replacements would that cause anything like this.
    Aug 2008
    Kennett Square, Pennsylvania
    a knock sensor and a TPS sensor should not cause a coolant leak. My bet is that the lid of the surge tank is somewhat corroded and rusted and it started leaking, they actually had quite a few problems with these and made a revised part. that or the radiator cap. You could always pressure test the system to see exactly where it is leaking. I would highly recommend replacing those sensors and fixing the leak before you drive it again though.
    Aug 2009
    Canada/Ethiopia/Madagascar
    Looks like it's leaking from the largest coolant hose, or from the side of the cap closest to it.
    ...Rob.
    That hose clamp was the first unauthorized part on my car. I've had exactly the same problem. Replace the hose clamp with one that screws on, or replace the hose entirely with authentic parts, including two new hose clamps. I chose the former and avoided burping the system by just snapping off the old hose clamp, and screwing the new one on.
    Jan 2011
    JAPAN
    where did you get the new hose clamp,
    Any auto parts store or hardware store. You're looking for a ring clamp basically. Or, for the stock unit, your Subaru dealer. However, you will have to remove the hose and thus burp the system if you replace the clamp with the stock unit.
    Jan 2011
    JAPAN
    i just tightened the clamp and it fixed the problem thanks!!! good thing too because im in japan were the nearest car parts store is 20 miles away
    Apr 2007
    8000' up in Colorado
    I thought for sure it was Hulk juice leaking from the turbo.....
    Scott
    Registered User economatic's Avatar
    May 2009
    Bend, OR
    No, I think it is Goblin blood.
