Results 1 to 8 of 8
This is a discussion on help with stuck nut within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I was trying to install some rear differential inserts today. I ran into a problem with a 17mm nut. It ...
    Registered User shadowpr's Avatar
    Jan 2011
    TX, NY
    help with stuck nut
    I was trying to install some rear differential inserts today. I ran into a problem with a 17mm nut. It wouldn't budge. I literally spent hours trying to get it to turn.
    Tried a breaker bar, air impact gun, using a pipe for leverage. Was about to get the dremel and cut it off, but found a few more 17mm nuts that i need to get off that wont move, so that sort of stopped that idea.
    Anyone have any tips?
    Registered User dbya rx's Avatar
    Jul 2010
    San Marcos, California, United States
    if its really cold where you are at, that may have an effect. try getting some heat down there to see if you can loosen up the frozen locktight.
    Stink-eye Mob #814004
    2010 WRX Limited Hatch - spt short throw...for now
    Supporting Member yamaha_rider619's Avatar
    Jul 2009
    colorado is home, Kansas is the temporary home
    did you try using pb blaster?
    Josh
    2003 Subaru Wrx Vf39'd
    Bugeye mafia #300
    Sponsored By: WRXPro.com
    Jan 2011
    TX, NY
    Quote Originally Posted by dbya rx View Post
    Yeah, i think it got up to 33 today. I'm a bit worried to use a torch to heat things up under there.
    Quote Originally Posted by yamaha_rider619 View Post
    was going to try some wd-40 tomorrow. is that similar?
    Moderator   Sasquatch's Avatar
    Apr 2004
    Southeastern PA
    Quote Originally Posted by shadowpr View Post
    Yes, but the consensus is PB Blaster is better.
    Moderator for: Aftermarket Vendor & Installer Review / Detailing Forum / Engine Modifications / Exterior & Appearance
    New Member Hangout / Off Topic / Tri-State
    Mods & Pics
    Jan 2011
    TX, NY
    ok. i'll have to find some tomorrow morning.
    any other tips?
    Apr 2004
    Southeastern PA
    Spray liberally and let it soak. Repeat. Another optional repeat.
    Good luck.
    Mods & Pics
    Jul 2009
    you can pick pb blaster up at any automotive place, i think even walmart and lowes.
    Josh
    Bugeye mafia #300
