Results 1 to 12 of 12
This is a discussion on Did my own oil change for the first time within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; After paying for my last oil change, I decided that it would just be easier to do it myself. ...
    Registered User shadowpr's Avatar
    Jan 2011
    TX, NY
    After paying $91 for my last oil change, I decided that it would just be easier to do it myself. I used an oem filter, and bought some Mobile 1 EP from walmart. Total cost was like $33.
    It went smoothly, for the most part. Put the car up on some ramps, and drained all the oil. Didn't see an old crush ring. I put a new crush ring on, and then put on the new filter. I might have tightened it a bit much. Then I put in some oil, and started the car. No leaks. So I finished putting the oil in. I think I put a little too much though. I put about 4.5 quarts in. Hopefully that won't matter.
    The only real complaint I have was that mother nature didn't make it nice. Doing this in 28 degree weather was not fun.
    Aug 2009
    Canada/Ethiopia/Madagascar
    Definitely a money saver, and relatively quick as you found. Surprised there wasn't a drain plug gasket; sometimes they're black from the factory, which disguises them, but if you've had oil changes done since then, maybe they forgot to put it on at your last change.
    Regarding overfilling; Subarus are more tolerant of a slight overfill vs under filling to a point, that point being when the lobes on the crank start turning the oil into a latte. Check your oil after the car has been sitting overnight. Use the distance between L and F to gauge how much extra oil you have (distance between L and F = ~1L = ~1 qt). If it's above the "hot" notch above F, then you're approaching too much.
    ...Rob.
    $91 for an oil change? Ouch!
    Moderator Donkey's Avatar
    Da boonies
    Yeah,did that include a reach around? That's insane......
    2002 FORESTER S
    1998 FORESTER S
    Jan 2011
    TX, NY
    Thanks. I'll see if i can check it tomorrow morning before I leave.
    After paying $91, I felt violated.
    Registered User Lengthwise32's Avatar
    Dec 2009
    DENVER, CO
    Here's the service specials from my dealer along w/ the 21.95 oil change.
    I'm sure your local dealer has the same thing online.
    Specials on new and used cars, trucks, vans, SUVs, parts and service specials.
    2009 WRX - South Denver, CO
    Texas, United States
    Quote Originally Posted by Lengthwise32 View Post
    Ohh yea, that looks like some high quality oil they're using there.
    I'd rather do it myself and fill'er up with T6.
    Jan 2011
    TX, NY
    I just found out that I put the crush ring in the wrong place. I put it on with the filter (it fit, so I assumed).
    I doubt this would be cause enough to redo everything, but just wanted some verification.
    It's been done before. Putting the ring on the filter is not cause to redo everything but it is cause to remove the filter, remove the crush ring, and put the filter on correctly IMO.
    Jan 2011
    TX, NY
    Guess I'll be doing a second oil change on wednesday then. Eh. Guess it'll be good practice.
    I would not bother changing the oil if the drain plug is not leaking. If the drain plug is leaking, then get a drain pan, let the car go stone cold, and QUICKLY use your thumb to keep the oil in while you remove the drain plug, add a crush washer in the correct orientation, and replace it. Press up gently when replacing the plug to minimize leaking.
    The filter will come off with minimal juice if you keep the dip stick on and the fill cap tight as they are, and let the car go completely cold.
    Jan 2011
    TX, NY
    Thanks.
    I don't think I'm leaking any, so I'll probably be able to leave the plug alone. It might even have an old one still on it.
