Engine stalling almost every time RPM Drops!!!!
Results 1 to 8 of 8
This is a discussion on Engine stalling almost every time RPM Drops!!!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Alright, my 03 wrx seems to stall/die almost every time i push in the clutch and the RPM drops. it ...
    saint peters
    Alright, my 03 wrx seems to stall/die almost every time i push in the clutch and the RPM drops. it happens after the car has warmed up. it has been doing it for a few years now but it has gotten so consistent these past few months. I have replaced the idle air control valve and nothing. battery is good, alternator is good. i do have aftermarket blowoff valve, boost controller, stock intake, catless turboback exhaust. i have attempted to see if there are any vacuum leaks and was unable to locate any if they exist. no CEL comes on. needs suggestions or help on fixing this issue!
    If i am not in my wrx, check the sky..
    CJ Keppel, on the fly.
    http://i97.photobucket.com/albums/l2...carshow018.jpg
    Moderator Donkey's Avatar
    Da boonies,Va
    Clean the MAF and throttlebody. Check the intake track for cracks/leaks. This is from the MAF to the throttlebody.
    2002 FORESTER S
    1998 FORESTER S
    Registered User MakeItRoar's Avatar
    Aug 2010
    Chicago, Illinois
    2006 WRX Limited -Pro-tuned VF-39, STI TMIC, STI factory I/C Sprayer, Throttle body Coolant Bypass, STI Exhaust, SPT Short Ram Intake, SPT Upper Front and Rear Strut Bar, Red Samco Radiator Hoses, STI Trunk, SPT Short Shifter, Aftermarket Rotors, Lamco Turbo Gauge, Catless Downpipe, Hella Supertones, RallyArmor Limited Edition Pink UR Flaps, 35% Tint, Grounding Mod, Walbro 255 Fuel Pump, SPT Heat Shield STI Piston Shift Knob!
    Hawk-Eye Alliance #430
    Registered User ALLWHEELDREAMS's Avatar
    Feb 2009
    wayne,pa
    Bump, hey guys my 04 sti is having a very similar problem. i got a misfire in cyl 4 cel and the idle stall started again.(cel is new with misfire) last time this happened (stall idle) it was a loose connection from SRI to inlet tube. this time there is no issue there. i had the plugs replaced and the cel never came on during the inspection! but it started with me after i left. so i lightly press on the gas and between 0-4% throttle pos. via APV2. the rpm drop lower then 175rpm (APV2). either more gas or lifting off, the car recovers. all this with a rough off kilter idle. but around 750rpm. any ideas? Have a compression test done? a smoke machine attached to see if there is a vac leak? all the above?
    Apr 2007
    8000' up in Colorado
    It would be better to start your own thread for starters...
    How many miles on your car? Any mods? What is the service history? What code is the CEL showing?
    Scott
    Feb 2009
    wayne,pa
    Thanks
    thanks for responding, im not on here much and thought it was better to "bump" this. but thank you, its a 2004 sti has 103,5xx with hks-SRI-Flat pate 3" CL DP- 3" CB high power . OTS stg 2 LC APV2 i got it stock with 68k and took my time in the past 2 yrs modding it. went from 93 stg 1 to 93 stg1 with CB then added SR and DP flash 93 stg 2. only a month ago or so i messed around with the LC. ive been doing some research and im thinking now it may be the 02 sensor. if i barley touch the gas pedal to create some form of induction it bogs down. not always to a stall while standing still but rough rough catches and when moving to a stop it stalls. but it runs like a champ other wise once you get going and dont tap the gas. also just last week the cel came on, apv2 said mis fire cyl 4. had the plugs done and inspection. cel never came on for him nor did it stall. i drove 2 miles and turned around due to cel coming on. o n moved the coil and mis fire did not follow. the cel comes on randomly seems to have nothing to do with the stalling issue directly. just now i cleaned the MAF with alcohol and a q-tip.
    Apr 2007
    Well to start with, that map isn't designed to run with an intake. That's a good place to start. See if cleaning the MAF helps. That still doesn't explain a misfire code though. That's usually plugs, coilpack, or wires.
    Scott
    Feb 2009
    wayne,pa
    it was running fine untill recent, the big change was the Turbo inlet tube and then it was fine for a lil. random cel and the stalling prob came back. im thinking it might be the o2 sensor? after trying that im just going to take it to a dealer and see what there computer system can say it is. the light is just so random! like today it came on while just warming up. reset ecu and it hast come back on after driving about 15 miles. so im just confused.
