Results 1 to 11 of 11
This is a discussion on '05 WRX Timing Belt Question.... within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i have been reading about changing my timing belt and i know its really important that i get it done ...
    Jan 2011
    i have been reading about changing my timing belt and i know its really important that i get it done (104k miles). But it is really important that i change all the pulleys and tensioners and water pump, cause that is an extra couple hundred bucks.... Just wondering what you guys think, my gut tells me to change it all while its all open and there, but if they are well known to not run out for a good 200k i might just change the belt and worry about the accessories on the next belt change
    thanks for the input
    Apr 2007
    8000' up in Colorado
    It all depends what kind of shape they're in, which is pretty much impossible to know. Either you can change them when things are apart for a bit of money, or wait for them to go and then it's a lot more expensive repair.
    Scott
    Jul 2010
    Cincinnati
    Change them now. A pulley bearing or water pump seizes and your in a world of trouble, I would even suggest that if you can't afford it all, don't do the belt for a couple months until you can. Running the belt an extra couple thousand miles should be perfectly fine
    Stink eye mob #727
    2011 WRX DGM Hatch, Protuned Stage 1
    Apr 2007
    Quote Originally Posted by jd92677 View Post
    Well if the timing belt goes, there goes the top end of the motor...
    Scott
    Jan 2011
    i am gunna get it all done at once, just wanted to see what you guys thought!
    thanks for the advice
    Apr 2007
    Quote Originally Posted by Duncman View Post
    Very good idea if you've got a little extra to spend. An ounce of prevention is worth a pound of cure.
    Scott
    Jul 2010
    Cincinnati
    Of course, but being recommended at 105k and going to , say, 108-109k should be perfectly fine
    Stink eye mob #727
    Jan 2011
    would you guys trust this kit, or should i buy the gates for double the price?
    Subaru Impreza WRX Turbo Timing Belt Water Pump EJ20T - eBay (item 370461959268 end time Jan-29-11 12:58:03 PST)
    I would buy the Gates kit
    Jul 2010
    Cincinnati
    On stuff like that, OEM
    Stink eye mob #727
