Maybe one of the fins on the turbine striking the turbo wall? If you bent the rod it spins on, it will wobble and grind against the wall.
This is a discussion on chirping sound 95 WRX! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hello, Since about a week ago, I have noticed a strange chirping/metal grinding sound coming from the turbo side of ...
Hello,
Since about a week ago, I have noticed a strange chirping/metal grinding sound coming from the turbo side of the engine bay whenever I reach about 3500RPM or just by quickly pressing the throttle, no matter what gear I'm in.
The car is a 1995 jdm wrx, 84000km and the only mods are catback exhaust and hks air intake. All the brakes, transmission, clutch, drivetrain are stock.
Popped the hood and got a few people to listen to it but hard to diagnose where exactly the noise is coming from. My dad suggested possibly the turbo wastegate, but I don't think this is the issue as it sounds more like a metal screeching too me than an air leak. Could this be something inside the turbo?
Thanks for your suggestions
2006 WRX Limited -Pro-tuned VF-39, STI TMIC, STI factory I/C Sprayer, Throttle body Coolant Bypass, STI Exhaust, SPT Short Ram Intake, SPT Upper Front and Rear Strut Bar, Red Samco Radiator Hoses, STI Trunk, SPT Short Shifter, Aftermarket Rotors, Lamco Turbo Gauge, Catless Downpipe, Hella Supertones, RallyArmor Limited Edition Pink UR Flaps, 35% Tint, Grounding Mod, Walbro 255 Fuel Pump, SPT Heat Shield STI Piston Shift Knob!
Hawk-Eye Alliance #430
ahh, my woes are over. put it on the four post lift today, the rattle was simply exhaust heat shield on the DP, corner was rusted off of bolt so was vibrating against upper half of shield.
