Results 1 to 11 of 11
This is a discussion on 02' wrx 110k miles, loosing oil but not leaking??? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hows it going ya'll? Just trying to figure this thing out. Someone told me once that turbos, if used hard ...
    Registered User tommyp's Avatar
    Dec 2009
    Ventura County, CA
    Just trying to figure this thing out. Someone told me once that turbos, if used hard will be the cause for some oil loss. But about a quart every week or two? No oil spots on the ground where I park every day/night either. I'm baffled. Can this mean the death of my car soon?
    Nov 2009
    It is called blow-by. What oil are you using? When was the last time it was changed?
    Dec 2009
    Ventura County, CA
    I change about every 5k miles or just less, have gone over once or twice. I have been using Mobil 1 5w-30 for about a year now.
    Supporting Member yamaha_rider619's Avatar
    Jul 2009
    colorado is home, Kansas is the temporary home
    First, change the oil every 3k miles. Second, many people have had problems with mobil 1 in there suby's, and many have had success with it. Try a different brand of oil, and change it at 3k miles and then see.
    Josh
    2003 Subaru Wrx Vf39'd
    Bugeye mafia #300
    Sponsored By: WRXPro.com
    Apr 2007
    8000' up in Colorado
    Quote Originally Posted by yamaha_rider619 View Post
    Sorry Josh, but I'm going to have to disagree wholeheartedly. The recommended oil change interval with Mobil 1 on the latest 911's is 20k miles. My brother is the head of lubricants (among other things) for Otis Elevator and Escalator North America, and a car guy, and talks directly to the engineers that design the stuff. It can last for 25k miles without a problem. 3k miles oil changes with synthetic are purely a waste of oil.
    If there's nothing on the ground, I'm with oguitar. The rings on the car are letting blow-by go through. There's really nowhere else oil can go than on the ground or through the exhaust.
    Scott
    Jul 2009
    He never said it was synthetic
    Josh
    Bugeye mafia #300
    Dec 2009
    Ventura County, CA
    Quote Originally Posted by oguitar View Post
    any good threads on this topic you guys know about?
    edit... forget it found one... here, ill share.
    http://www.bobistheoilguy.com/blowby.html
    Dec 2009
    Ventura County, CA
    "Detergents and Molybdenum Disulfide work together to clean the soot and deposits off of your rings allowing them to better seal the combustion chamber."
    Anyone ever do this themselves to help reduce blow-by?
    Apr 2007
    I'm an idiot, I just assumed anybody who knows cars these days uses it.
    Quote Originally Posted by tommyp View Post
    Nothing is going to magically repair a physical problem in the engine. A heavier weight oil is where I'd start, a 10w-40. What weight are you running now?
    Scott
    Dec 2009
    Ventura County, CA
    Yeah I understand, just curious. I am using 5w-30 now, I will try the 10w-30 next time around and see... Thanks.
    Dec 2009
    Ventura County, CA
    I really meant...I will try the 10w-40 next time around and see... Thanks.
