Results 1 to 8 of 8
This is a discussion on Possible rod KnocK ?????? plz help ASAP. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Well, ever since I figured out that the correct type of gas for my 04' WRX was octane 93 thats ...
    Oct 2010
    Well, ever since I figured out that the correct type of gas for my 04' WRX was octane 93 thats all I have been putting, ran good except for hard to turn on due to low charged battery(fixed).
    Unfortunately, yesterday my father borrowed the car and today the car has been acting very weird......
    * Weird click noise after releasing the throttle petal(rev).
    * When warm, the car started to shake (I felt it -_-) all while smoke was coming out from hood scoop.
    All I would like to know if the gas that my father put caused this or just a coincidence. Also if that weird noise a rod Knock.
    INFO___
    04' WRX 145k miles Stock.
    History of P0304, still trying to fix- Next attempt replace o2 Sensors.
    Thanks in advance for everyone that has helped, seriously.
    Nov 2010
    Columbus, Ohio, United States
    Sounds like your dad either drove the car way to hard n blew it. is that the case? or did he put gas it? not wasn't 93?
    Apr 2007
    8000' up in Colorado
    What gas were you putting in it before the 93 and for how long?
    Scott
    Oct 2010
    Quote Originally Posted by vr4drivin View Post
    Trust me... my father is not the hard driving type of guy, seriously. BTW he used it to go to work since I needed his car to help my sister move to her campus.
    The car when first purchased(sep2010) we accidentally put in octane 87(regular, for one day) and quickly changed it to octane 89(premium) -- Both having the same symptoms I described.
    Nonetheless I figure out (by clubwrx & nasioc) I was originally suppose to use octane 93(used since Sept until yesterday), and what do you know it worked, no more weird noise or any other issues stated.
    So any idea what caused this??
    Apr 2007
    So it has worked fine since you've run 93 then?
    It can and most likely will knock with a lower octane if you run it that long because the ignition is being retarded due to the lower octane fuel, which the engine isn't designed for. Count yourself lucky if you didn't cause permanent damage and it's running fine now. Never again put in lower than 91.
    Scott
    Oct 2010
    ooo ok, but yea basically no problems at all when I use 93 excluding the misfire code(p0304)which I'm in the process of fixing - Replacing the 02 sensors.
    Thanks for everything, seriously. FYI I still have not put 93 yet I just stop driving the car until I figured out what is causing this, so tomorrow I'll put 93 since its almost empty. *hoping for the best, I'll update this thread tomorrow after a quick drive btw*
    Apr 2007
    o2 sensor is a likely reason for the p0304 code. Pay attention to the label on the fuel door of your car in the future that says "premium fuel only." They put it there for a reason.
    Glad to help educate
    Scott
    Oct 2010
    ooo lol. .... FYI someplaces here in NJ premium is 87, which my father always says. I on the other hand tend to say "93 (amount$) cash". Either way thanks again for everything
