Results 1 to 12 of 12
This is a discussion on Help! CLUTCH PETAL THUMPING! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey experts driving my 02 wrx i feel i thumping feel when resting my foot on the clutch petal. I ...
    Nov 2010
    Columbus, Ohio, United States
    Hey experts driving my 02 wrx i feel i thumping feel when resting my foot on the clutch petal. I just had byers install a new oem clutch 2 weeks ago. The feel of thumping seems to be mostly when i make a slight or right hand turn. I have no idea what it could be.Doesnt matter what gear i'm in or neutral coasting a turn. Also my power steering seems to be acting up as well. when i'm stoped in neutral i turn the wheel back n forth as far as it can go it acts if it doesn't want to keep turning when i know there is still at least a half turn left. makes a squeeking noise if i hold it as far as it can turn. help would be greatly apprieated
    Jul 2004
    Seattle, WA
    When do you feel the thumping in the clutch pedal? When the clutch is pushed to the floor, when it's engaging/disengaging, or when when its up all the way?
    Have you inspected/replaced the power steering belt? If the belt is too worn (loose) it will squeal if it's not able to turn the wheels.
    What is the condition of the axles?
    Are there any indicator lights on (CEL)?
    Nov 2010
    No lights are on in the car. I looked at the axles and they look fine to me. I feel the thumping mostly when the clutch is up all the way, and my foot is just resting(no pressure). I only feel it when clutch is in whether it be in gear or not, foot off the petal just resting. Havn't inspected the belt yet. what should i look for. Also the resovoir is on the low side of hot min.
    Nov 2010
    body of the car has 96K
    Apr 2007
    8000' up in Colorado
    What kind of clutch petal is it? Rose? Tulip? Daffodil? That makes a big difference.....
    Scott
    Nov 2010
    Um i don't know just a stock petal. 02 bugeye
    Apr 2007
    Well I've always had a clutch peDal in all of my cars, to go along with the brake and gas peDals....
    /sarcasm
    Scott
    Nov 2010
    any idea of what it could be i feel the thumping thru the clutch pedal even if i'm not in gear
    Apr 2007
    If a fluid is below the hot min, then that's a good place to start. That's your clutch fluid correct?
    The steering problem sounds like either the power steering fluid is low, the belt is loose, or your pump is going.
    Scott
    Nov 2010
    no the hot min was the power steering resovoir. I didn't know there was a clutch fluid thought clutch used the power steering. lil do i know. this is my first wrx had it for 2 months. is that the resovoir behind the top mount? i appreciate the help
    Nov 2010
    correction i thought clutch uses brake fluid
    Jul 2004
    Seattle, WA
    Clutch fluid is brake fluid, it's all connected to the brake master cylinder. The steering fluid is connected to a separate reservoir.
    Use the dead pedal. Don't keep your foot on the clutch.
