same thing here, someone is offering to sell their stock 05 sti, he said it should be a direct fit.
This is a discussion on What modifications does this radiator require to fit in my '02 WRX? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Koyo OEM Replacement Radiator Manual Transmission Subaru WRX / STI 2003-2007 at RallySportDirect.com This is the radiator I'd like to ...
This is the radiator I'd like to buy to replace mine which is currently leaking through the top plastic reservoir. In the comments one buyer said it worked fine he just had to make some "minor modifications". Does anyone know what he's talking about?
If you have a bugeye then the radiator did not have a fill neck or cap. The 04+ WRX's got a fill neck and cap on the radiator. You just need to "T" in the overflow line of the new radiator to the existing one that goes to the overflow tank.
easy enough, i figure, since 02-07 wrx&sti shared alot of the same parts, thanks
