I am also a Subaru tech, 99% of the time I run into this it is the Alternator...did someone put in an aftermarket unit? Did you load test the battery? Alternator output test performed? I would personally even go as far as to put another Subaru reman. alternator in it and see if it works, especially if this unit you have on there is aftermarket... check that both electrical connectors are good and tight also, I have seen people forget the lock washer on some of them before and the nut backs off a tad...
LinkBack URL
About LinkBacks
