first oil change, turrible - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 37 of 37
This is a discussion on first oil change, turrible within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Originally Posted by den9 so i hear, for the past 6 years, but i havent once ever heard a first ...
  1. #31
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    Quote Originally Posted by den9 View Post
    so i hear, for the past 6 years, but i havent once ever heard a first account story or 2nd hand story
    I haven't heard any accounts of engine seizing or anything that was directly attributable to Fram, but a guy did dissect a large number of filters, examined their construction, and sent the filter elements to a lab to determine they're effectiveness. His findings are here: Engine Oil Filters
    Basically, Fram filters are the lowest quality filter you can get. They CAN (not guaranteeing they will, but can) leak dirty oil back into your engine, are generally poorly constructed. They may not cause any problems right away, but why risk it when a quality filter is just a few dollars more? I know a lot of OEMs use Fram filters, but I'll stick with higher grade Mobil 1 filters myself. Just my opinion...
    As for oils, I use full synthetic, but don't really have a favorite brand yet. So far my Valvoline Full Synthetic has been fine, and it was pretty cheap.
    2007 Outback 3.0R wagon
  3. #32
    KHP
    KHP is offline
    Registered User KHP's Avatar
    Oct 2010
    Reno, NV
    Quote Originally Posted by wrx wagone View Post
    The blue Subaru filters are made by Fram.
    Unfortunately yes . But it's really the only oil filter to be built to Subaru specs. Subaru's use an unusually high bypass valve pressure of ~23psi if I remember correctly. That means more filtered oil assuming the filter works correctly because it was made by Fram . Aftermarket once are usually a lot lower bypass pressure meaning less filtered oil. Ohh.. well.. I have 70k warranty so if the car breaks down I'll slap them the receipts of the Subaru oil filters that I bought along with all the approved fluids. Then the claim shouldn't be an issue.
  4. #33
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    bypass valve pressure? What bypass valve?
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
  6. #34
    Registered User lytlec's Avatar
    Jan 2009
    Central PA
    Ya know.... The bypass valve pressure....isn't it like 543 psi......?
    <-------- Taylor Swift.
    Hawk-Eye Alliance #137
    First Mods...what to do.
    Subaru Guide
  7. #35
    Registered User Eric05mx's Avatar
    Oct 2010
    PA
    I've never used OEM oil filter's for any vehicle. Purolator or Mobil 1, save receipts, have fun.
    2012 WRX ice silver metallic
    Protuned by Agile Auto 315whp/342wtq @ 20.5psi
  8. #36
    KHP
    KHP is offline
    Oct 2010
    Reno, NV
    Hmm... I couldn't catch if you were being sarcastic, if you are then otherwise if you're not then, bypass valves are built into can oil filters. The valves are usually closed in normal operations allowing oil to pass through the filter element. Once the pressure rises due to rising engine RPM's the bypass valve opens allowing oil to bypass the filter element. The valve is also used as a safety for when the filter element is completely clogged making sure that the engine is lubricated in the expense of the oil not being filtered.
  9. #37
    KHP
    KHP is offline
    Oct 2010
    Reno, NV
    oops...
