first oil change, turrible - Page 2
Results 16 to 30 of 37
This is a discussion on first oil change, turrible within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Fred Beans Subaru is pretty close to you. You might want to consider that for next time....
    May 2005
    Phillytown, PA
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Another hint....
    I only use K&N Oil filters... they have a 1/2 inch nut on the top of them. They are so easy to take off, it's not even funny.
    If you don't want to shell out the $$ for the K&N... I'd purchase an oil filter end cap with a nut on it. Cheap and easy to remove the oil filter:
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    Registered User ElVerde's Avatar
    Aug 2010
    Newport Beach, CA
    ^The problem is that the oil filter end cap they sell at auto part stores doesn't fit the factory subaru filter (which is waaaaay overtightened).
    Big pliers solved my problem...and I have a wrench that fits my aftermarket filter for future changes. Also, hand tightening (1 turn past contact) goes a long way in reducing oil change headaches.
    ~ADAM
    70 El Camino SS clone
    2011 WRX Sedan in Satin White Cobb Stage 1+AEM Cold Air Intake
    Click here for my Progress Thread
    Installing HellaSupertones? Click here.
    N.E.R.D. #4
    Devout Practicalist
  6. #19
    Nov 2006
    Denver Metro Area
    Definitely. I only hand tighten. No reason to use a wrench to tighten. Also, make sure the rubber gasket is in the oil filter, and that you lube the rubber gasket with the new oil before putting it back on. That helps a lot to reduce headaches later down the line.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  7. #20
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    It sounds like bugeyes have it easy. I changed the oil on mine for the first time since I've owned it, and everything is located together within easy reach just aft of the "skid plate".
    I have ramps, but didnt bother with them. It was the easiest oil change I've ever done.
    Shucks (O Reilly, whatever) has a sale until Jan. 25 on 5 quarts Valvoline full synthetic with a Mobil 1 filter for $28! I was pleased.
    Sent using Tapatalk
    2007 Outback 3.0R wagon
  8. #21
    Dec 2010
    Doylestown, PA
    yes i tried the purolator in the store on the wrench i bought, took it to the garage and nope, didnt fit the stock one, couldnt even manage to get a screw driver up there to stab the filter. thought it would be best to just add oil and drive home instead of having a holey filter that still wont come off.
    well if anyone can get me the size for the stock filter that would be sweet
  9. #22
    Dec 2010
    Doylestown, PA
    yes autozone has the same deal with a fram filter for 25, this was semi synthentic, full synth next change.
  10. #23
    Dec 2010
    Doylestown, PA
    Quote Originally Posted by wrx wagone View Post
    nope, i wouldnt ever consider it, not even in windy 10 degree weather. now that i know the way around the car alittle, shouldnt take so long, except getting the damn filter off for the first time
    Another hint....
    yes, i bought the cup wrench, but like i said i dont know what size fits stock.
  11. #24
    Oct 2010
    Portland, OR
    Quote Originally Posted by den9 View Post
    Those Fram filters are garbage. I would stay away from them. There's lots of info about the inferior components they use.
    Sent using Tapatalk
  12. #25
    The first change has involved swearing at an overtight filter for our last two new cars.
    Fumoto makes a good product IMO. The oil changes in my Honda and my Subaru no longer require any tools at all. The filter and the drain can both be done by hand. Nice.
  13. #26
    Registered User dbya rx's Avatar
    Jul 2010
    San Marcos, California, United States
    Quote Originally Posted by Rambo View Post
    +1. an oem subaru filter is about $8 with taxes and the dealer parts dept i go to usually will throw in the crush washer on the house, how can you beat that!
    Stink-eye Mob #814004
    2010 WRX Limited Hatch - spt short throw...for now
  14. #27
    Dec 2010
    Doylestown, PA
    Sent using Tapatalk
    so i hear, for the past 6 years, but i havent once ever heard a first account story or 2nd hand story
  15. #28
    Quote Originally Posted by dbya rx
    I get a 6-pack for ~$25; see if they'll discount a larger quantity for you...
    Resident Tuner @ WTF Tuning
  16. #29
    May 2005
    Phillytown, PA
    The blue Subaru filters are made by Fram.
  17. #30
    Moderator Donkey's Avatar
    Da boonies,Va
    I generally just use the Purolator Pure One filters. Adjustable oil filter wrench FTW.
    2002 FORESTER S
    1998 FORESTER S
