Results 1 to 8 of 8
This is a discussion on Struggling to Start ???? HELP, PLZ. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Well this is not the first time, but I just thought I fixed the issue before so ignored it. Sometimes ...
    Jun 2010
    New Jersey
    Sometimes after turning the engine off and then a few minutes later back on the car tends to struggle to stay on but does not turn off (RPM drop really low then back to normal (700rpm -warm)). In addition the car begins to smoke a little somewhere around the turbo. All in all I would like to know what exactly is this and how to fix it. I've tried researching this but had no luck finding anything.
    _
    INFO:
    04' Subaru WRX
    Stock 145k miles.
    No codes just have to finish drive cycle.
    _
    Thank you all in advance.
    Pic to soon to come ...... 19 yrs old. Drive a Subbie( Im a newbie). 3rd Year Of college going to third.
    Moderator Donkey's Avatar
    Da boonies
    Probably the IAC valve needs to be cleaned or possibly replaced.
    2002 FORESTER S
    1998 FORESTER S
    Jun 2010
    New Jersey
    Are you sure?? cause the smoke was coming from a different location. To make it more clear I tried to look for a picture so I can better explain the issue.
    There was not a immense amount of smoke but to a certain point were an observer can notice it. Smoke was coming from. .....
    THanks again for the help, greatly appreciated.
    Apr 2007
    8000' up in Colorado
    Starting has three factors: fuel, spark, and air.
    If your car is having issues just starting and keeping idle, one of these is messed up. I wonder if you just have a bad relay;
    Scott
    Da boonies
    Quote Originally Posted by nunez07c View Post
    Smoke coming from that area would probably be a post turbo leak (dp)and have nothing to do with how the car idles. So if you cannot 100% tell us where the "smoke" is coming from then there is little to do from the interweb with out better details. For all I know that "smoke" is just oil or some other contaminant burning off your exhaust. Also "this area" doesn't help as much as saying "wastegate arm" or "downpipe".
    2002 FORESTER S
    1998 FORESTER S
    Jun 2010
    New Jersey
    Ok, so today before heading out I decided to take a picture of where I believe the smoke is coming from, hopefully it good enough to understand better. BTW I would have like to ask someone around me about this issue, but unfortunately I'm currently the only subaru WRX owner where I live.
    Well here is the pic.
    And again thanks for the help everyone, gladly appreciate it.
    Apr 2007
    Sorry, but you're pointing to three different things that aren't really related, so it's hard to say what might be wrong. The wastegate isn't going to have smoke come from it. There could be a leak between the turbo and downpipe, but that's unlikely unless it's been removed before. But the heatshield is missing so maybe there was some work done there before.
    The other two lines are coolant (I'm doubting myself a little whether both are though, can't remember and can't look at my old car for reference since all that stuff has already been removed!). Maybe you have a coolant leak that's dripping onto the turbo? That shouldn't cause any issues with restarting it though.
    Scott
    Jun 2010
    New Jersey
    sorry this took so long, I took a better picture after closely looking at where did it come from. Hopefully this helps.
    Seriously guys thanks for everything, hopefully I'll gain enough knowledge/experience to be as good as you guys.
