Could easily be any one of the rest of the vac lines tied in with the blue T. Also could be an issue with the charcoal canister.
This is a discussion on P0457 replaced a lot, what is left? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i had a local dealership look at my cel 7 times within a month and a half. cel is p0457, ...
i had a local dealership look at my cel 7 times within a month and a half. cel is p0457, emission leak, loose gas cap. The service manager told me they cannot find the leak and I need to go somewhere else to get it fixed. The fuel pump gasket and the fuel cap has been replaced twice, blue t piece vacuum has been checked, turbo inlet repaced with oem.
At this point the mechanic smoke tested it multiple times and cannot find the leak. I will take it to a dealership on tuesday, but i want to try to find the problem myself tomorrow. Any advice would be greatly appretiated.
Josh
2003 Subaru Wrx Vf39'd
Bugeye mafia #300
Sponsored By: WRXPro.com
So basically hoses connected to the t piece or the vapor canister?
Josh
Bugeye mafia #300
Look at the canister closely and look at the harness that has a clip there. That clip sometimes gets moisture trapped inside, corroding the contacts and causing a CEL.
I will check that out tomorrow for sure. I would have hoped the tech from the dealership would have looked at that though...
Josh
Bugeye mafia #300
I don't know if the fuel system parts from my STi would fit Josh, but you're welcome to any of them for free.
Scott
pm'd you scott
Josh
Bugeye mafia #300
I'm now going to charge you $1000 a part when you show up at my house tomorrow.
Scott
Bad news for me![]()
Josh
Bugeye mafia #300
