Results 1 to 9 of 9
This is a discussion on 2006 WRX Low Beam Headlight Replacement within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; One of my low beam headlights just went out on my 2006 WRX so I got some new ones to ...
    Apr 2009
    One of my low beam headlights just went out on my 2006 WRX so I got some new ones to replace them. I open up the car manual and it says to just take them to the nearest Subaru dealer cause I might get electrocuted if I try to do it myself.
    I'm usually pretty handy although I don't have a ton of experience mechanically or in this case I guess electronically. If I can follow a set of instructions with no problem can I just do it myself. And if so is there a guide out there on how to do it so I won't electrocute myself?
    Thanks!
    Moderator Donkey's Avatar
    Da boonies
    How are you going to get electrocuted if the lights are off? The WRX has halogen lamps not H.ID.'s like the STI. That warning is for the STI. The owners manual does not explain how to change the bulb? Reading comprehension is important in order to follow directions.... (j/k) Also change them in pairs. Don't just do one side and don't buy any of the b/s "bright white" bulbs. Something like Phillips Xtreme Power or Osram Night Breakers will make a noticeable difference. Good luck!!
    2002 FORESTER S
    1998 FORESTER S
    Registered User kbrownmann's Avatar
    Nov 2009
    Melbourne, Kentucky, United States
    just take the dust cap off, get a small phillips head screwdriver and take out the screw right under the dust cap. dont lose it. pinch the bracket together and take it out. then you can remove and unplug the light. simple process.
    tip remember which way the bracket was so it will be a lot easier to put back in lol.
    Hawk-Eye Alliance #Infinity
    Moderator   Sasquatch's Avatar
    Apr 2004
    Southeastern PA
    Daniel Stern Lighting Consultancy and Supply
    Dan knows bulbs ... at least which is best to use for a given car.
    Moderator for: Aftermarket Vendor & Installer Review / Detailing Forum / Engine Modifications / Exterior & Appearance
    New Member Hangout / Off Topic / Tri-State
    Mods & Pics
    Registered User dbya rx's Avatar
    Jul 2010
    San Marcos, California, United States
    this is a pretty bad ass website not just for headlamps, but all bulbs interior and exterior of your vehicle. it will give the you alphanumerical code for the headlamp bulbs that you need for replacements. obviously you dont have to use sylvania but at least you know the #.
    OSRAM SYLVANIA - Replacement Guide - Start
    if you are afraid of electrocuting yourself, just make sure you just unhook the negative terminal from the battery (the black one)
    Stink-eye Mob #814004
    2010 WRX Limited Hatch - spt short throw...for now
    Quote Originally Posted by Donkey
    +1
    Another option is GE Night Hawk Platinums
    Da boonies
    Quote Originally Posted by dbya rx View Post
    It has to do with the HID STI headlights. The ballasts have capacitors in them. Capacitors store energy......like a battery.
    2002 FORESTER S
    1998 FORESTER S
    Da boonies
    +1
    Yup! Used them on my wife's car. Another great place to get bulbs is www.candlepower.com
    2002 FORESTER S
    1998 FORESTER S
    Apr 2009
    Thanks for all of the advice. I originally read WRX-STI as meaning both WRX and STI. Actual changing of the bulbs was cake walk. Although you didn't mention that to replace the leftside bulb you have to remove the battery from the car. By then I had already done the right side so I figured **** it and managed to get it out without blowing anything up.
    Everything worked out no problem and now I got two working lights and much brighter lights at that.
    Thanks again!
