Results 1 to 10 of 10
This is a discussion on Has anyone blown the ringland in cylinder 4? if so what were the symptoms prior to th within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Like the title states, I'm trying to figure out if I have a blown piston ringland in my 4th cylinder... ...
    Feb 2010
    SL,UT
    Like the title states, I'm trying to figure out if I have a blown piston ringland in my 4th cylinder... please tell me what the symptoms were prior to the engine rebuild to see if I can get an idea if this is what I'm facing...
    Hawk-Eye Alliance #801
    Yes... you need engine management for engine modifications
    http://www.clubwrx.net/forums/tuning...ne-mods-6.html
    Texas, United States
    Low compression on cylinder four would be a pretty clear sign.
    Feb 2010
    SL,UT
    I did do a compression test and the engine was cold and it was 1-120 2-110 3-120 4-120... I've has a misfire issue and can't find out what the cause is...
    Ive checked these things so far...
    1.replaced the spark plug
    2.swapped the coil packs (still p0304)
    3.cleaned the maf and switched it back to a paper filter
    4. Compression test
    5.injector was checked with a osilascope and was pulsing normal..
    6.dataloging and nothing was abnormal
    7. Ran a new ground wire from the coil pack and tested the ground levels
    Captain James of the SS Impreza has gone down with the ship Drews's Avatar
    Aug 2008
    Davey Jones Locker
    Quote Originally Posted by 06scoobyrex View Post
    4. Compression test
    Are you tuned at all? If you are I would ask your tuner to take a look and see what's going on. Maybe your ECU pulled too much timing or something. Did you try resetting the code?
    Hawk-Eye Alliance #Eleventy,000,000,000|N.E.R.D. Member 20,000
    Stable: 07 GMC 2500HD, 06 LGT, What's left of an 04 STI, 03 WRX, 98 RS, 86 Brat
    Resident Clubdub Debbie Downer. I'd love your ideas if you kept them to yourself. Subarus suck, get a new wife.
    Jan 2005
    Eh, whaaaaa?
    Quote Originally Posted by Drews View Post
    Done that. Datalogging showed no signs of knock what-so-ever. No learned parameters to indicate prolonged knock issues either. Everything was inline except for a small boost oscillation issue which was remedied quickly and showed no signs of causing issues like a misfire. Datalogs look clean and good and he's still hitting boost targets just fine. This was in the 1.5 hour datalogging session we did a couple of nights ago. It would seem that if this issue was more than prevelant it would have reared its head in that time, but nothing happened.
    It seems to be a come and go issue, not sure what is causing it.
    Cody
    Feb 2010
    SL,UT
    Bump...
    Registered User Medic_538's Avatar
    Nov 2011
    Mankato, MN
    Sounds just like my issues and I now have a bad ringland in #4.
    Started as a light miss on idle. Couldn't feel it under boost.
    Started to notice more and more oil in my IC
    Then mixed with coolant= Chocolate Milk
    Then another compression check showed #4 at 60 psi
    Sounds like unfortunately your driving a ticking time bomb. Good luck!
    Jul 2010
    Cincinnati
    Might want to try a leakdown test to see if that reveals an issue
    Stink eye mob #727
    2011 WRX DGM Hatch, Protuned Stage 1
    Feb 2010
    SL,UT
    Yep... Had to replace the engine... Old thread...
    Jul 2010
    Cincinnati
    Ahhhh!!! Sucked in, glad I could help
    Stink eye mob #727
