p0304... still stumped, possabile piston ring issue?
Results 1 to 14 of 14
This is a discussion on p0304... still stumped, possabile piston ring issue? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; okay, so... I've had this misfire issue and I have done the following to diagnos it... 1.cleaned MAF sensor 2.replaced ...
    Feb 2010
    SL,UT
    2.replaced the spark plug
    3.swapped around the coil packs
    3.did a compression test (when cold) and readings were 120,120,110,120
    4.tested the ground connections
    5.ran a new ground wire to that cylinder
    6.took it to a dealer to check it out (it was close to closing on the weekend and they said the injector sounded okay)
    7.I've done datalogging and everything seemed normal made a few adjustments
    So... with that being said, I called a local shop here (they specialize in subarus) and they told me that it's most likeley a piston ring issue... They told me that they've got a few in with simular issues and they did compression tests on them and have came back normal, plus then they tear down the engine and find burned up piston rings... They said it would be $1800 to rebuild it... So... I'm at a loss at the moment and I just can't see if it were a ring issue that wouldn't show up on a compression test... Please help, I'm about ready to put my head through a wall...
    Hawk-Eye Alliance #801
    Jul 2010
    Cincinnati
    I agree with you, a bad ring should show up on a compression test. Did you do a wet and dry test? could be a valve issue, could be a vacuum leak. Can't really think of anything else it could possibly be. The dealer said the injector sounded OK? You could try swapping injectors to be sure. Let us know what you come up with
    Feb 2010
    SL,UT
    It was a dry compression test and I'm sure a bad valve would've shown up as well cause the valves work as the motor turns.. It could be a vacuum leak somewhere but there is so much to check its retarded... I'll keep everyone posted, I hope the guy was just jerking me around about that, cause the car only has 61K on it and it is virtually stock other then a retune and cbe...
    Aug 2009
    Canada/Ethiopia/Madagascar
    A leak down test should point you in the right direction.
    ...Rob.
    Feb 2010
    SL,UT
    What all does a leakdown test show? To my understanding I thought it just showed if the head gasket had a good seal...
    Aug 2009
    Quote Originally Posted by 06scoobyrex View Post
    It will pinpoint the source of the leak.
    The neat thing about a leakage test (as opposed to a compression test) is that it's faster and easier to figure out where the pressure is going. If you hear air coming out of the tailpipe, it indicates a leaky exhaust valve. Air coming out of the throttle body or carburetor would point to a leaky intake valve. Air coming out of the breather vent or PCV valve fitting would tell you the rings and/or cylinders are worn.
    ...Rob.
    Feb 2010
    SL,UT
    Allright thanks man... do you know how mutch a shop would charge to do one?
    Aug 2009
    Not sure; I paid ~$120 IIRC at a performance shop; I think the dealership bends you over on a comp/leak down test as they're mandated to do both at the same time from what I hear.
    Good luck.
    ...Rob.
    Jul 2010
    Cincinnati
    We charge an hour labor but, of course, there's no standard. It'll vary from shop to shop, I would call around
    Feb 2010
    SL,UT
    Okay thanks guys... I did find this thread about ringland symptoms and I think the 2nd or 3rd post down showed a drop of 50psi on the cylinder with the ring issue... I know it varies from car to car, but the guy at the shop told me there could be an issue with as little as 10psi difference.... I just think there would be a larger difference then 10psi if it were a ring issue... all of my cylinders read 120 and cylinder 2 showed 110, yet the 4th cylinder is the 1 with the issue...
    here is a link to that thread I did read that...
    What are the symptoms of a cracked piston ring? - Subaru Impreza WRX STI Forums: IWSTI.com
    Jul 2010
    Cincinnati
    General rule I use is less than 15% variation is OK so 10 psi with your numbers is usually acceptable and I wouldn't think cause a misfire code
    Feb 2010
    SL,UT
    Yeah... that guy at the shop I talked to said he's seen ring problems with as little as 10psi difference, so I think there would be a larger difference in the pressure...
    Moderator Donkey's Avatar
    Da boonies,Va
    You didn't try everything. Swap injectors to see if the problem moves and do a combustion chamber cleaning. Also run some injector cleaner through a couple of tanks. Also the valve clearances need to be checked.
    IF YOU HAVE A MISFIRE CODE ,PLEASE READ THIS!!!
    2002 FORESTER S
    1998 FORESTER S
    Feb 2010
    SL,UT
    At thithis point I'm most likely going to take it into the dealership... I've tried as much as I can to my mechanical ability so I'm sure they will find it easier and save more money in the long run then just checking different things that might not even correct the problem...
