I'd use the OEM again.
This is a discussion on SLIPPING CLUTCH within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; time for a new clutch, has been slipping for the past week or so. car cant hook up at all. ...
time for a new clutch, has been slipping for the past week or so. car cant hook up at all. it's a 02 wrx with sti top mount, vf39 and pink injectors with a pro tune. lookin for some advice on what clutch to use but want something strong, very.
Yup, just go with the OEM again. Why put a strong clutch on it?
Scott
i heard of some ppl going with the sti oem. do you know if that would work or even fit. and you have any clue how much a new clutch is gonna run me
i just want something strong that will last something i can beat on and not have to worry about replacing another
It does not work, WRX/STI clutches are different P/NsOriginally Posted by vr4drivin
The stronger a clutch, the harder it is on the transmission. A clutch is cheaper to replace than a transmission.Originally Posted by vr4drivin
You should be buying the "weakest" clutch with proper torque capacity. Likely, an OE replacement or Exedy Organic clutch would be adequate. You also need to factor in the cost of a new flywheel.
I had put a Centerforce dual friction Kevlar clutch in my Tacoma 4x4 10 years ago. I loved it, but that was also a whole different vehicle.
2009 WRX - South Denver, CO
Scott
thanks for the advice. whats the best set up for the wrx clutch/ flywheel should i go lightened
I would use the OEM flywheel.
anyone been thru the dealer for a full clutch replace, how much was it.
Should i replace the flywheel at the same time?
got the new clutch in, very different from befor, it takes alomost no force to push petal in. Is this normal. oem was put in.
