Results 1 to 5 of 5
This is a discussion on CEL P0420 please help within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; CEL went on and the code is P0420, which is apparently something with the cat. Serious issue? Any suggestions? Anyone ...
    Aug 2010
    New Jersey
    CEL went on and the code is P0420, which is apparently something with the cat. Serious issue? Any suggestions? Anyone had this problem? (2003 wrx wagon)
    Jul 2010
    Cincinnati
    Quote Originally Posted by subiwagon03 View Post
    Very common problem, it is a catalyst efficiency code and if the car is stock, they would more tham likely need to be replaced. There is no problem driving it like it is if you don't mind the light being on. If the car is modded, different story. Is the car modded in any way? If so, how?
    Jul 2004
    Seattle, WA
    Please list your mods.
    If the car has a catless downpipe then the Computer needs to be tuned.
    Aug 2010
    New Jersey
    car is 100% stock
    The car does not need a tune even with an aftermarket down pipe. However, since the car is stock, take the code at face value and troubleshoot. Begin with the wiring and go from there.
