Need help finding exhaust manifold bolts
Results 1 to 4 of 4
This is a discussion on Need help finding exhaust manifold bolts within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So i developed a small leak that turned into a big one so i investigated and found i was missing ...
    Dec 2010
    TEXAS
    So i developed a small leak that turned into a big one so i investigated and found i was missing a header bolt on the passenger side. I have looked up and down subaru.com diagrams and several others i have found the exhaust part but no numbers for the bolt and my local dealer was no help. It is the exhaust manifold bolt that bolts into the passenger side head.
    Aug 2008
    Kennett Square, Pennsylvania
    they are actually studs, go to your dealer they might even have one in stock, tell them you need the head stud for the exhaust...
    here you go... http://subarupartsforyou.com/cp_part...p?partid=12636
    Dec 2010
    TEXAS
    Thanks EvoEatr however the dealer does not sell the studs they are assembled with the head so i bought a nut and matched it up the size is m10-1.25 and 30mm long worked great. I must have had a small leak for sometime i also noticed a leak in the rear after the repair a hole in my axle back it is next on the list.
    Aug 2008
    No problem man. Try some epoxy or some JB weld on the hole in the axle back if its really small
