Hit a curb! Help!
Results 1 to 6 of 6
This is a discussion on Hit a curb! Help! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Well, I hit a curb a couple weeks back and did some damage to the drivers side front wheel and ...
    Dec 2010
    Hit a curb! Help!
    Well, I hit a curb a couple weeks back and did some damage to the drivers side front wheel and suspension. I have thus far replaced the lower control arm, tie rod, stabilizer linkage, axle, rim, tire, and had an alignment done. However, there is a bad vibration in the front, especially when I turn the wheel to the right, even slightly. The wheel bearing and hub seem fine, and even the strut looks fine. Any ideas?
    Jul 2010
    Cincinnati
    Quote Originally Posted by WR9-2X View Post
    Looks can be deceiving, the hub may be bent slightly even if it looks straight. Being that's the only thing you didn't replace on that side, I would suspect that is your problem
    Apr 2007
    8000' up in Colorado
    Man those curb monsters are out in force again this year!!!
    Scott
    Dec 2010
    Yeah, I see that I am not the only one that had an unfortunate curb encounter...
    Jul 2004
    Seattle, WA
    I've read about people needing to replace the strut after a curb hit.
    Does it make the noise when you go over uneven pavement, or just when you're turning?
    Dec 2010
    It only makes the noise when turning right, which should mean it is the left bearing. I just ordered a knuckle/hub/bearing assembly and will get that swapped out and see what happens.
