Results 1 to 5 of 5
This is a discussion on The old hesitation unanswerable question... within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a 1994 wrx stock jdm and it has developed a hesitation when i give it all its got ...
    Registered User hukasabi's Avatar
    Jun 2009
    canada
    I have a 1994 wrx stock jdm and it has developed a hesitation when i give it all its got or there abouts... it drives nice otherwise...
    Subaru dealer says not sure maybe coil cut in and out... but no engine lights equal no diagnosis... and ive seen people tear cars apart fixing everything except this prob...
    Anyone with the same issue? or easy elimination suggestions..?
    cheers...
    Aug 2009
    Canada/Ethiopia/Madagascar
    There are a lot of JDM WRX and STi's on my local forum (in Calgary, Ab); without hesitation the first response from others with regards to any ignition issues is: have you replaced the coil packs yet?
    I don't have any personal experience with JDM's however.
    ...Rob.
    Jun 2009
    canada
    oh yeh im in canada aye... any ideas where can i source ej20 coil packs without being ripped...?
    Texas, United States
    Check your grounds too.. or better yet, remove and clean all grounds regardless. I believe a poor ground actually caused one of my coil packs to fail.
    Aug 2009
    Quote Originally Posted by hukasabi View Post
    That's what i figured, but you forgot the "d", so I surmised that you could have also been from Canaa, Brazil What part of the country are you in? Typically more JDM's in Canada than the US.
    No idea where to source the packs from. I think '02 WRX coil packs can be used...somehow.
    ...Rob.
