Anyone at all?
This is a discussion on About oil in my WRX within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Could I get the link to the oil thread for my WRX or could some one just tell what oil ...
Could I get the link to the oil thread for my WRX or could some one just tell what oil should I put in my 06 WRX. Synthetic oil obviously and its the winter time now. I'm at a long day at work and on my iPhone and I've searched for a topi on it with my phone and it just won't find it. Thanks in advanced who ever helps.I'm picking up oil on my way home that's why I would like to know now rather then wait to get home and then go back out.
Anyone at all?
Search "oil tsb" or "what kind of oil should I use" and these threads come up:
Oil TSB for 2006+ Subarus
and
??What oil should I use??
Hope this helps.
More than you will ever need to know: Welcome
There's lots of good oil out there, so it's pretty much up to you. I personally use Rotella T6 5w-40. Amsoil is great stuff, but it's a little pricey for me. A lot of people also use German Castrol. The only one I've had bad experience with is Mobil 1 5w-30, but people generally have mixed opinions about it.
I couldn't find M1 diesel truck 5W-40 this time around so I went with Rotella T6, again 5W-40. I'd been using M1 since 13K mi, so seven years or so. I'm sure it'll be fine with the Shell. I tend to buy whatever 0W-40 or 5W-40 is on sale or convenient at this point.
The best viscosity for your use pattern, and the best oil, can only be determined with certainty empirically, by performing used oil analyses. Second best is to look at the results from other people with similar motors, in similar climates, and with similar habits.
I use 0W-40 or 5W-40 synths, but I am out of warranty (so I have no concerns over a claim denial if I don't have the correct viscosity oil on the receipts), I've done a used oil analysis way back when to get me on the right path, and I'm a conservative driver who does his best to maintain his vehicles. Your use patterns and your climate may vary, plus from your avatar you're under warranty.
If you are under warranty, follow Subaru's requirements to the letter and keep all receipts.
So I guess I'm going to go with the Rotella T6 5w-40. Its winter time here so that wouldn't be to thick would it? I just want to make sure my engine is safe under high revs and 5w-30 is thin oil if I'm correct, but maybe better for the winter. I read some great reviews on the Rotella T6 oil and the funny thing is, is that I never heard of it before or new it was made. lol I was thinking about using Royal Purple but that stuffs almost 10$ a quart here, that's ridiculous, is it even worth it for that stuff?
Just thought I'd let you guys know I changed my mind at advanced when i went to pick up some oil. I picked up the Valvoline Full Synthetic 5w-30 oil, with a K&N Oil filter. They had a special going for 28$ or something like that. I noticed the Shell oil T6 is only available in the 4Qt. jug? My car takes like 4.28qts so meaning I would have to buy 2 4qt jugs and technically waste the other 4qts. I don't think keeping it after opened for a few months would be worthwhile.
The Valvoline should be fine.
My car takes 5 quarts, so I always buy two or three jugs of the Rotella at a time. It's less than $20 a jug at Walmart, and it all makes it into the engine at some point in time, so technically none of it is wasted. You always need some extra oil around to top off between changes. I check my oil at least once a week.. of course I've got a sticking valve right now, so I'm going through more oil than normal until my next build in January.
